Cleaning Up Engine And Trans? - Engine Degreaser
its the same that everyone else is talking about. Stock the hose is very short and they decided that it would be a good idea to put it right in front of the radiator fan.
I took the bottle out and extended mine all the way to the ground...past the wheel. So the extra oil just goes into the ground (its not much)
For heavy deposits I use mineral spirits in a pump sprayer. Soak and rinse.
to get the last bit od residue off, I use a bit of foamy engine brite. Never takes more than the time to wash the truck to have the underside perfect.
Dave
Dave
dizzel
Aug 2, 2007 08:47 PM
djp9747
17
Mar 13, 2005 02:47 PM
I thought the vent was that rubber tube that hangs down (drivers side, front) and gets hot oil drippings on everything the wind decides to deposit it on,, "Yikes" what is this can your refering to?
