03 Clutch/pressureplate/single mass flywheel in a 06 G56 is it possible???
Old Sep 29, 2009 | 10:47 PM
RiverRat2's Avatar
was just wondering if anyone has tried it?????
Old Sep 30, 2009 | 08:38 AM
rich's Avatar
end of the crank is different so a std flywheel will not work
Old Sep 30, 2009 | 03:40 PM
RiverRat2's Avatar
How so??? cause if it needs to be opened up I have a Mill and a lathe if the Mods can be done to the Flywheel?????
Old Sep 30, 2009 | 04:12 PM
patdaly's Avatar
Why not throw a South Bend in it and not worry?
If you have to buy a flywheel anyway, migth as well get a clutch that can take abuse.
Old Sep 30, 2009 | 09:15 PM
rich's Avatar
because of the way they mount the flywheel to a flex plate makes it need something like a spacer thats casted in the new flywheel to get the proper clearance. just went thru the ordeal of changing mine out about 3 weeks ago
Old Sep 30, 2009 | 10:18 PM
RiverRat2's Avatar
Supposed to be getting a newly installed 03 Flywheel clutch and pressure plate,, out of a totaled truck,,, I already have a well used 06 Dual mass FW shop door stop to compare to,,, mine went out @ 68K,,,,,, gonna do some checking,,,, we'll see might make a good thread!!!!
Old Oct 2, 2009 | 06:06 AM
BLACKBEAR's Avatar
Rich I think I would be looking at what some one is doing wrong!!Or I would be putting some gauges on if you don't have any.We have an 89 with over 600.000 and never has had a head pulled we are on the 6 rebild frunt end 2 transmission 3 power stearing pump shaft. the 3 set of injectors. It is now jest a stand by.
Old Oct 2, 2009 | 09:49 AM
rich's Avatar
i'm not sure what your talking about. i run gauges but i also run about 60 to 120k a year and about 80% of that is hauling around 23k. i dont buy a truck to drive around in i get em to make money by working. Almost all of those trucks the truck gave out before the motor. went thru 7 nv4500 on the one 98.5 and 4 clutches.
Old Oct 11, 2009 | 02:25 AM
Mike Wood's Avatar
South Bend makes a conversion kit that changes from the stupid DM flywheel to a single mass and bolts right in with no adapters. It's been in my truck for around 10k now with no issues. A little more noise (which is normal I'm told) but the vibration of the grenaded DM is gone.
MW
Jona Gold
29
Jan 19, 2025 06:36 PM
sailed2japan
Feb 7, 2011 09:10 PM
CORam2
84
Oct 28, 2010 11:11 PM
panama
Jan 9, 2007 03:44 PM
DmaxEter
28
Dec 6, 2006 04:46 PM
