I'm surprised....
Old Oct 10, 2009 | 01:01 PM
dott's Avatar
I'm surprised....
how clean my engine looks inside. It has 150K miles on it. A gas engine would be all caked up with sludge. This pic is how it looked when I removed the valve cover. I haven't even wiped the gasket surface yet.
Old Oct 10, 2009 | 01:30 PM
06RAM2500's Avatar
Ever seen an engine that was a lifer on Pennzoil??
Old Oct 10, 2009 | 02:41 PM
trik396's Avatar
What oil do you run?
Old Oct 10, 2009 | 02:50 PM
dott's Avatar
Gas or deisel? I suspect it's not good.
Old Oct 10, 2009 | 02:51 PM
dott's Avatar
I wish I could tell you. I just bought this truck 2000 miles ago. It had 149K when I bought it.
Old Oct 10, 2009 | 02:58 PM
Sandaholic's Avatar
I haven't even had my valve cover off yet. Anybody that has, is this standard that this valve-train is so clean?
Old Oct 10, 2009 | 03:08 PM
trik396's Avatar
Yes it's normal... you can still see the black oil on the rockers and bolt heads. Looks like what a good oil will do... keep soot in suspension.
Old Oct 10, 2009 | 03:10 PM
Sandaholic's Avatar
Thanks. Just making a mental note for later on down the road when I finally get in there.
Old Oct 10, 2009 | 03:58 PM
MikeyB's Avatar
Can also add Texaco Havoline to that list.
MikeyB
Old Oct 10, 2009 | 06:44 PM
Bigiron's Avatar
I have a Chevy Suburban with a 12 valve Cummins in it since 1989. It has 300K + miles on it and it is just as clean under the valve cover as the picture above. I think it is a function of the greater quantity of detergents in diesel rated oil. Back in the 60s we used to clean the sludge out of our hot rods by filling them with Delo and then changing the filters a couple times. It worked!
Old Oct 10, 2009 | 07:19 PM
dott's Avatar
Well, good, that's what I'm running right now.
Old Oct 11, 2009 | 03:14 AM
DaveB.inVa's Avatar
Take the oil cap off and use a flashlight... you can get a good peek at your valvetrain that way. I'd say yours will look very similar to the picture above.
Haulin_in_Dixie
May 18, 2005 04:09 PM
Begle1
Dec 21, 2004 08:57 PM
bdramsey
53
Dec 8, 2004 02:27 PM
Shovelhead
Feb 17, 2004 07:28 PM
Shovelhead
Nov 14, 2002 08:13 PM
