03-05 dodge
Well i have a 04 3500 and have had good luck ! The worst thing i have had go wrong is two bad drive lines and i think i am on my third or fourth set of u-joints i 36,000 miles and the dealer can't seem to find the problem
I love my 03! i have only had to shell out cash for 6 new injectors, ball joints and ujoints (drive lines, included). so about 3 grand worth of work
but it runs like a top, and now that all that stuff is fixed, I should be good to go for a while!
.....but it runs like a top, and now that all that stuff is fixed, I should be good to go for a while!
03's look for cracked alternator bracket. Make sure the ball joints are good, and make sure the heater runs correctly on all settings (blend doors can break).
Overall, I think the trucks of that era are very nice.
From: Used to be missoula, montana: Now in Sonoma County California
03-04 triple nickle gets better mileage. shop for 3.73 gears fuel pressure on my 03 got low at 70k miles, dealer installed the intank conversion pump.
had weheel bearings go bad at 70k miles and needed an axle joint, one ball joint was getting loose so i did them all when i did my hub coinversion. u joints so far seem to be holding up but i imagine at 100k i'll put in some greasables.
I like my 04.5 also. 93k and the only major issues were front end parts which I replaced with greaseable parts, fuel pump which I replaced with a FASS 150, water pump, one u-joint and minor interior flaws. Other than that, she has been good to me.
My '04 has been great. Make sure you have an in-tank lift pump, and check the ball joints for play.
I recently added a BD steering box stabilizer and I think it's a must-have for these trucks as well, and a cheap upgrade.
joebishop23
Oct 29, 2007 10:19 AM
wreedCTD
27
Sep 30, 2007 09:52 PM
texasredrider
30
Nov 14, 2004 10:35 PM
