03/04 Wastegate
03/04 Wastegate
Is the waste gate on the 03/04's adjustable or is it "crimped" at the factory to freeze the factory setting? I thought I had seen something on this but I can't find the thread! It looks like it is crimped or dimpled in place to prevent adjustment. Factory service manual states 24 to 27 lbs normal and my '03 only hits 18 to 19 lbs under steady full load, not counting spikes. I would like to step it up for some baselines before I swap to a larger turbo.
-Richard
-Richard
Originally posted by 800summit
just take the wastegate off and put the 2 washers between the wastgate and turbo. this is like adjusting the rod 1/8"
-Richard
The rod that goes into the waste gate is factory crimped. all you are doing is moving the actuator forward the thickness of the washers. between the turbo and the wastegate actuator
