is front 4wd axel asy same for srw & drw?
Old Dec 8, 2014 | 09:43 AM
paulr's Avatar
I had a hard landing & bent the axel tubes. I need to replace the front axel assembly to fix the -1.8 degree camber problem on each side. The question: Is there a difference between front axels with single-rear-wheel(this is what I have), and dual rear wheel front axel? the part number on the axel is (P)52104
2003, 3500, 5.9 diesel, 4x4, 3.73 ratio, manual 6-speed
Old Dec 8, 2014 | 10:36 AM
cLAYH's Avatar
Watch the ratios, most DRWs in that era were 4.10 ratio. Otherwise once you unbolt the extension adapters it should work just fine.
lawdog800
19
Mar 31, 2011 09:26 AM
J Lent
60
Nov 3, 2009 09:14 PM
89dieselkong
Apr 5, 2009 05:20 PM
dragginlx
15
Mar 9, 2007 11:32 AM
JImbo1
Apr 9, 2003 07:46 AM
