difference in 04 vs 04.5
Old Dec 19, 2012 | 11:18 AM
jpvdh's Avatar
Hey guys im just looking for some info and your thoughts between the 2004 and the 04.5 cummins. What are the differences? Pros and cons of both. And what you would rather run and why. Lets get into it here. Drivetrain fuel systems exhaust ect.
thanks
Old Dec 19, 2012 | 12:31 PM
Spooler's Avatar
Do a search, alot of info on it that has already been discussed.
Old Dec 19, 2012 | 08:00 PM
06RAM2500's Avatar
I'll help save you the time.
04.5's went to an electronic waste gate control, upped the horse power to 325, and the injector nozzles are at a different spray angle.
Old Dec 19, 2012 | 09:43 PM
tantruck's Avatar
thanks
Check your PM's, I sent you a good link for info.
The 2003 and early 2004's only had 2 injection events per combustion cycle and get a bit better mileage that the 2004.5's and later. The 3rd injection event on the 2004.5 and up was for emissions and it also turns the oil black much quicker, ( not really anything to worry about but it annoys many folks.)
However, the 03/04 were rated for a bit less HP, either 255hp for the SO motor or 305hp for the HO motor and they did not have a cat converter like the 2004.5+. Some of the 255 hp motors got the 47RE auto trans while the 305hp I think got the 48RE trans with some upgrades.
The 2004.5+ had 4 inch exhaust a bit larger turbo in stock form.
Just a couple of things that come to mind.
Old Dec 20, 2012 | 01:13 PM
SOhappy's Avatar
04.5s also had catalytic converters, well....stock from the factory anyway.
Old Dec 20, 2012 | 11:20 PM
ironbrew's Avatar
So... when we go to order injectors, we order for an 05, and when we order other parts, such as a raptor fuel pump, again we order for an 05?
Old Dec 21, 2012 | 06:59 AM
jpvdh's Avatar
Yes.
Old Dec 22, 2012 | 06:37 AM
Little Joe's Avatar
You can't run 04.5-07 injectors in 03-04 engines. The piston bowl is not the same and injectors have different spray angle.
CMN_NOT_STROKN
Nov 22, 2024 02:55 PM
GO 4LO
Feb 20, 2003 02:08 PM
Cutthroat
Dec 29, 2002 12:38 PM
j
Nov 23, 2002 05:51 PM
jet
Nov 16, 2002 09:32 PM
