Where is good place for gauge light power hookup?
Old Dec 7, 2007 | 02:51 PM
psmopar's Avatar
I just installed my fass pump and isspro FP gauge on my 01 dodge 3500.
Everything went pretty well .....but I am unsure where is best place to hook up or tap off to get power off the headight/switched circuit for power for gauge light? I looked up in the underdash area and normally a few spare 12v sources are left open for just such added accessories.
If I don't have to take dash apart to access back of headlight switch I would like to know best place to get switched light source for gauges. I am not a fan of jamming wire into fuse box either.
Where have any of you guys hooked/spliced for switched light source?
Thanks..
Old Dec 7, 2007 | 03:10 PM
JPR Ram's Avatar
From: My head lays down in Murrieta, but the day light hours are spent in San Diego, Ca.
You know, they make fuse piggybacks. It has a wire coming outa one end and the other replaces the fuse it self and has a spot for the original fuse and one for the new wire.
Old Dec 7, 2007 | 03:12 PM
JPR Ram's Avatar
Or use a test light and find a wire on the rear of the hedlight/dimmer switch which is on/off and dims.
Old Dec 7, 2007 | 03:13 PM
Busboy's Avatar
3 screws takes out the ashtray and the silver metal clip comes out of the whole thing, the bulb then will slide out of the metal clip. There are 2 wires to the light just take the one with power when lites are on. This comes from the dimer so the gauges will dim.
Old Dec 7, 2007 | 03:48 PM
psmopar's Avatar
Cool... thanks!
I will try that when I get home. That'll work because I mounted the FP gauge just below that next to shifter console.
Old Dec 7, 2007 | 03:52 PM
Bersaglieri's Avatar
I used the cab lights wire that runs right past the fuse panel in the truck.
-Dustin-
Old Dec 7, 2007 | 04:07 PM
qwest's Avatar
The fuse in the panel marked Inst lights ( I think ) anyway it is fused ,Variable
voltage from the rheostat sw, a piggy back fuse here will give you
variable voltage for the gage lights on a seperate fused circuit.
Old Dec 7, 2007 | 04:14 PM
Dr. Evil's Avatar
I think you are referring to the Illumination fuse
Old Dec 7, 2007 | 08:05 PM
D2 Cat's Avatar
If you remove the ashtray for that wire, I think it is the orange one. Easy to get to and works to dim your gauge just as you like your dash.
Old Dec 7, 2007 | 11:20 PM
displacedtexan's Avatar
I have been unable to find them locally, where did you get yours?
I tapped into the wiring harness behind my headlight switch.
Old Dec 8, 2007 | 06:27 AM
qwest's Avatar
advance, pep boys, napa ( but cost more)
Old Dec 8, 2007 | 09:48 AM
Dr. Evil's Avatar
http://www.partsexpress.com/pe/pshow...number=071-580
stratos201proxl
Jan 16, 2014 11:04 AM
JARHEAD
Feb 20, 2013 11:44 AM
nymegacab
Jun 21, 2007 02:49 PM
4RGSP
Jan 16, 2005 06:11 PM
TON4FUN
Jul 11, 2003 02:11 PM
