What's purpose of having two batteries installed?
Old Aug 4, 2009 | 03:20 AM
JasonblkZ06's Avatar
I also thought it had something to do with diesels having high compression and typically large engines, large flywheels, flexplates, heavy rotating assemblies etc. and large starters etc. They are harder to turn over than your typical gasoline engine with lighter parts and lower compression.
Old Aug 7, 2009 | 03:27 PM
supr's Avatar
If you live in the south, you could proably get by with one battery, but why? Batteries do not cost that much, copared to everything else related to these beasts. If one battery leaves you starded, is it worth the risk?
The engineers who put thse together did the batteries right.
Old Aug 7, 2009 | 04:24 PM
olddodgetrucks's Avatar
1st gen had only one batt,started at -35 ,has same grid heaters,overkill,someone looked a ford/gm and said we should have 2 batt. because it looks impressive
Old Aug 7, 2009 | 04:31 PM
rednekroper05's Avatar
also need two batt.s if your like some of us that havent grown up fully and have a amp and two subs requiring some power. Sad part is that if i turn my amp and radio up to max it will still dim all the lights on my truck
Old Aug 7, 2009 | 08:31 PM
Originally Posted by jrs_dodge_diesel
The 1st gen Rams with a Cummins only had one battery to my knowledge. Starting in 94 (the first year of the 2nd gen), 2500 and 3500 trucks with the Cummins have 2 batteries.
Yes, but our old trucks have a big ol' group 31 battery, same size as you would find under a heavy truck. Of course, a heavy truck uses 2 or 3 of them - but still it's a big battery. Even a low buck one has at least 1050 CCA.
Old Nov 26, 2019 | 01:05 AM
Gerardo's Avatar
Weird
Originally Posted by mstep3
This may be a dumb question, but what's the purpose of having 2 batteries installed in the 2500. Did most of the 2500's come from factory with 2 batteries?
I got an 02' & have never replaced the batteries on it. Getting close to having to replace them.....
my brother has a 1998 ram 2500 and he has replaced one of the batteries
Old Nov 26, 2019 | 02:27 PM
nothingbutdarts's Avatar
^ ^ ^ ^ ^ Never a good idea to replace just ONE of the batteries if it has two, it can mess up a lot of stuff on these trucks! Just saying!
Old Nov 30, 2019 | 11:57 AM
SIXSLUG's Avatar
Two is one, one is none.....they have two to power the grid heaters when cold.
MikeThomas
Nov 27, 2019 09:50 AM
flyingd
Aug 10, 2013 05:56 PM
markm4
Nov 3, 2007 11:46 PM
mulepackin
14
Jan 30, 2007 09:04 PM
apache
Dec 18, 2004 11:05 AM
