What tire pressure?
Old Apr 12, 2013 | 06:20 AM
high bid's Avatar
Once you change/remove the factory tires I don't believe you should go buy the recommended tire psi found in the owners manual or inside the door jam. Tire sidewall would be more applicable for tire psi.
Old Apr 12, 2013 | 09:51 AM
johnh's Avatar
Originally Posted by infidel
If you want to get technical about it:
Paint or chalk a line across the treads on one front and one rear tire then go for a short drive on dry pavement.
If the line wears off more on the outside of the tread pressure is too low.
If it wears more in the center it's too high.
You want the line to wear off evenly
For empty driving 65 front, 55 rear works for me.
wow! high pressures.... my tires wear like iron with 30 rear and 40 front empty. the lines on the tires are the basis for my pressures.
since my retirement, i don't haul any weight other than pulling a small trailer with my ATV's
Old Apr 12, 2013 | 06:26 PM
infidel's Avatar
I've always found the pressures on the door jam and tire to be way too high for a comfortable ride on a truck.
Always figured they were the ratings for full load.
Old Apr 14, 2013 | 02:25 PM
KATOOM's Avatar
I have E rated TOYO M/T's. When they were installed they set them at about 40 psi front/rear. I thought that was way to low. After watching them wear and how they felt, I slowly upped the pressures to accommodate the best ride and wear for whatever I was doing. Currently, running empty I have around 70 psi in the front and around 50 in the rear. When I tow my 5th wheel, I have 80-85 psi in the rear. Seems like everyone has their own preference.
Old Apr 14, 2013 | 03:01 PM
Diesel Dave2's Avatar
Pickin on the wrong admin...
Bill...What tire pressure are running on your 95 3500 hauler??
Been running 65 front and 50 back...
Old Apr 14, 2013 | 11:12 PM
KATOOM's Avatar
This isn't meant to hijack the thread topic but I think that shocks will play an important role in relation to tire pressure and ride quality. I can dial my Rancho 9000's to the softest, or softer settings, and lessen the harsh ride depending on the air pressure. With 70 psi in the front tires, the truck is surprisingly soft riding. And thats not a plug for Rancho's either but just noting that if I forget to air down the rear tires and turn the shocks to the softer setting, I might as well be riding on solid tires. Point I guess I'm trying to make is, the stiffer the shocks, the more jarring will be transmitted to the cab from higher pressure in tires.
Old Apr 15, 2013 | 12:05 AM
joem's Avatar
true, I notice that off road vibration in my CTD is much less with my new bilstien 5100's that what it was with the old rusty things the previous owner had on it. As for sidewall flex, I use low PSI for rock crawling on my Toyota and with 15 psi in the tires the amount of sidewall flex makes it ride like im on jello-- super smooth on 6" pit mine gravel.
Old Apr 15, 2013 | 11:03 AM
infidel's Avatar
When using my goose neck hauling 25k I use 65 front, 80 rear.
Old Apr 20, 2013 | 02:28 PM
oldkimmer's Avatar
.............I put the Michelin LTX A/S LT265/70R17 on my 01 quadcab long box and run 80 psi front and rear 24/7 365 days a year whether its -40* or +100*F.......wearing excellent with a nice smoothe ride........45,000 miles on them so far............kim........
Old Apr 20, 2013 | 02:33 PM
mtdoragary's Avatar
I haven't ever found a tire that can equal a Michellin. They are pricey, but worth the money.
Old Apr 22, 2013 | 06:29 PM
Red_Angus's Avatar
ive heard ppl swear up and down about michelins but could never afford them.
the size i mentioned is still within the 3% margin. it doesnt even show on the speedo. the popular front tire pressures mentioned here are the same as those listed in the booklet supplied by the manufacturer. but with anything made by anybody, it is always up to the end user to determine what works best for them.
Dave88LX
14
Sep 1, 2011 11:36 AM
4RnrRick
Feb 27, 2007 11:25 AM
I PASS GAS
May 12, 2006 11:19 PM
FrankB
Aug 17, 2004 12:27 PM
ffemt1271
16
Jan 9, 2003 11:19 PM
