water temp sensor
Old Jun 5, 2008 | 08:44 PM
lews930's Avatar
water temp sensor
Ok, I searched but nothing jumped out at me. My temp gauge(water) seems to have quit working. It worked prior to losing a hose a few months back. Someone suggested an air pocket. I tired everything.
Is there a ay to test the sensor before I buy another? Is it possible to test the gauge?
thanks in advance
lewis
Old Jun 6, 2008 | 10:05 AM
infidel's Avatar
Many times when replacing the fuel hoses at the rear of the engine the connector to the water temp sensor gets unplugged.
Check it out at the top rear driver's side of the engine.
Old Jun 6, 2008 | 08:28 PM
lews930's Avatar
I checked it. I even removed it to buy another one. NAPA wanted $70 but a local independant factory trained cummins mechanic told me to only buy factory sensor. I dont want to buy a part if I dont need to
lewis
Old Jun 6, 2008 | 09:05 PM
BigIron70's Avatar
Cummins Guru
Air pocket would not prevent sensor from not working. To test gauge ground the sensor wire and if the gauge pegs to hot you have a open sensor. Replace the sensor.
Old Jun 7, 2008 | 09:17 AM
infidel's Avatar
a local independent factory trained cummins mechanic told me to only buy factory sensor
He is probably correct. Never hear much about water temp sensors going bad but when the oil pressure sensor goes bad it's waste of your money to use an autoparts generic sensor. They just don't last.
Old Jun 8, 2008 | 06:15 PM
lews930's Avatar
How would I clear an air bubble? seems far fetched but I'll try it as well as the gauge check.
thanks for the help
Old Jun 8, 2008 | 07:37 PM
GAmes's Avatar
The little hose on top of the thermostat is connected to a wobble valve. It takes care of air in the system.
Old Jun 8, 2008 | 08:06 PM
lews930's Avatar
thank you very much
broncobilly
Nov 2, 2006 11:02 PM
packfan25
23
Aug 3, 2006 07:05 PM
tyssniffen
Feb 11, 2006 01:28 PM
firesine
Nov 24, 2005 10:58 AM
jeepfun
Jan 10, 2005 03:20 PM
