Warning Alarm
Old Jun 12, 2008 | 12:08 PM
samasaurus's Avatar
Warning Alarm
I have a warning alarm going off intermittently. It dings but no warning lights are on. And all the gauges look good. Has anyone had this problem or know what might be causing this?
Old Jun 12, 2008 | 12:19 PM
Lil Dog's Avatar
Doors switch? There are three wires to the switch and it may be shorting out or coming loose. I had a problem with my seatbelt buzzer going off all the time. Pulled the fuse in the panel, can't remember which one, but that killed it. Funny thing is it still rings for my lights being on, or key in which is good.
Old Jun 12, 2008 | 12:31 PM
samasaurus's Avatar
It may be my seat belt sensor. Not to long ago my seat belt light was staying on even when my seat belt was on. But hasnt done this for awhile.
Old Jun 12, 2008 | 01:04 PM
vzdude's Avatar
DTR's 'Go to Guy'
see if the check guages lamp comes on at the same time? There has been issues with the instrument cluster and the oil pressure sender. IIRC, a new sender and a ecm flash will fix the issue.
Old Jun 13, 2008 | 03:09 PM
SIXSLUG's Avatar
You may have aburned out bulb in the warning lights. A quick removal of the dash bezel and instrument cluster is the only way to check this. Just a thought.
Kurt
Stormin_Norman
Mar 4, 2004 12:45 AM
L. D. Bryant
Apr 1, 2003 09:07 AM
wick
Nov 15, 2002 02:54 PM
BIG&BAD
Nov 6, 2002 01:53 AM
