Trans temp gauge
Old Nov 15, 2003 | 10:06 AM
scook6's Avatar
Trans temp gauge
Where can I get a good temp gauge for my tranny? Are they hard to install? Don't want to trust idiot light too far!
02 2500 Quad cab 47RE 5.9 24V
Old Nov 15, 2003 | 10:48 AM
waam's Avatar
Lest we forget
Re:Trans temp gauge
I use Auto meter, purch. from Summit Racing 2 and 5/8 dia. white face. Mounted on trany. floor hump. Made my own brk. to hold it. Bought aluminum pan from PLM Inc. in Inglewood, Calif. Holds two more qt's. Pick up sensor goes in pan. I dr. and taped my own and put hole very close to the discharge oil line. Ground wire you can attach to metal under air bag sensor cover also on the trany hump. Wire for the light, some people tie into the ash tray light wire or go to the fuse box and tie into the dash light fuse, that way it will dim with your dash lights. I went to the fuse box cause I tied my hot wire there also. If you put an aluminum pan on you need to purch. a new flat gasket, like cork or rubber. Hope this will maybe be of some help.
Waam Holland, Mich.
Old Nov 15, 2003 | 10:51 AM
scook6's Avatar
Re:Trans temp gauge
Hey Waam do you have an RV?
Old Nov 15, 2003 | 10:59 AM
waam's Avatar
Lest we forget
Re:Trans temp gauge
Yes I do Can read my description underneath my answer. Or you can e-mail me direct by looking up my profile. We are in the wrong spot here to talk about RV,s
Waam Holland, Mich.
Old Nov 15, 2003 | 12:44 PM
y-knot's Avatar
Re:Trans temp gauge
I to would recomend the AUTOMETER line of gages, they are the best. Also SUMMIT RACING is a wonderful place to do business, great prices,fast service.
Old Nov 15, 2003 | 01:26 PM
Shovelhead's Avatar
Administrator / Scooter Bum
Re:Trans temp gauge
I'm using Isspro EV series gauges to monitor the critical stuff.
Easy to read both day and night.
www.isspro.com
I bought my whole gauge set-up from Rod at www.wildcatdiesel.com
click on my profile for a link to my gallery
Old Nov 15, 2003 | 01:34 PM
TPilaske's Avatar
Re:Trans temp gauge
I picked up all my AutoMeteres from E-Gauges I have the sport-comp series. I would also recommend the replacement line from Dodge that is already tapped for a temp sensor from the tranny. This will give you the best/most accurate reading of just how hot your fluid is! Unfortunately I don't have the part number handy... :-[
Tony
Old Nov 15, 2003 | 02:17 PM
Shovelhead's Avatar
Re:Trans temp gauge
Dodge part # 5011244AA
Old Nov 15, 2003 | 02:20 PM
scook6's Avatar
Re:Trans temp gauge
Thank you guys You have been very helpful.
Old Nov 15, 2003 | 03:30 PM
TPilaske's Avatar
Re:Trans temp gauge
[quote author=Shovelhead link=board=5;threadid=22455;start=0#msg209947 date=1068927444]
[/quote]
I was going to put in my post that Ed would probably have the part #
Old Nov 15, 2003 | 03:33 PM
Shovelhead's Avatar
Re:Trans temp gauge
Old Nov 15, 2003 | 04:08 PM
scook6's Avatar
Re:Trans temp gauge
Hey guys thanks again for all you help. This the third gen 2 truck I have had, but the first diesel. I will never have another gas truck!
Old Nov 15, 2003 | 04:21 PM
Shovelhead's Avatar
Re:Trans temp gauge
[quote author=scook6 link=board=5;threadid=22455;start=0#msg209972 date=1068934109]
[/quote]
;D Been there, Done that. ;D
Old Nov 15, 2003 | 08:51 PM
billg's Avatar
Re:Trans temp gauge
While you are at it, it would be a good time to install pre-turbo pyro and boost gauges. I got mine from West Texas Turbo Diesel. http://dot-westtexasturbodiesel.com-....com/INDEX.htm Chase Aldridge is a great guy to busness with. I got everthing I needed in one package. Mounted all 3 on the pillar.
1985cucv
Feb 18, 2010 02:03 PM
mar67655
Mar 21, 2009 05:35 AM
Richpwb
Aug 15, 2008 08:01 PM
djgaston
Oct 30, 2005 03:18 PM
live wire
Jul 21, 2003 07:26 AM
