Tires vs 410's
Old Aug 21, 2005 | 01:48 PM
boostedte37's Avatar
Tires vs 410's
I have 4:10 gears with auto tranny and right now I'm running 285 size tires. I was thinking about going to the 315's. Good idea or bad? I don't do alot of heavy towing and would they fit without a hella lift?
Old Aug 21, 2005 | 01:51 PM
yfz450guy's Avatar
i was wonder the same but i tow some. thinking of goung a little taller on the next set.
Old Aug 21, 2005 | 07:31 PM
BigBlue's Avatar
I ran 315's with nothing more than a 2" front end leveling kit. Nothing else. They rubbed at full lock on the lower control arms but nothing bad. I'd definately do the 315's with the 4.10 gears.
Old Aug 21, 2005 | 08:35 PM
Thanks for the reply BigBlue Yea I'm turning about 2400@ 75 so the 315's should lower that somewhat
Old Aug 21, 2005 | 09:04 PM
BigBlue's Avatar
I'm turning 18-1900rpms at 70.
Old Aug 21, 2005 | 10:09 PM
Crimedog's Avatar
Go with em. I have 3.54s, so far the heaviest I've towed was 8,000 lbs. It is a little smokey but definitely doable. I think 315s and 4.10 gears are the perfect combo.
Old Aug 21, 2005 | 10:29 PM
torquefan's Avatar
Yep, I sure wouldn't worry about the overall gearing being too high. I tow with 3.55 gears and still wouldn't mind slightly higher gearing.
Old Aug 22, 2005 | 06:09 PM
GlennRMK's Avatar
I agree
35s and 3.55s and I like it!
Old Aug 22, 2005 | 08:10 PM
How do you like the pro comp mudds? could use some opinions on other mudd tires I'm running wild country's now which were on it when I bought it, fairly cheap tire
Old Aug 22, 2005 | 08:45 PM
TxDiesel007's Avatar
I agree with BigBLue
If u have 410s go with taller tires, and utilize the highway mileage, if you have 355s i dont like anything larger than a 285, yes the torque can overcome it, but anything else is a lil harder on the drivetrain in my opinion... Its great though, but i tow alot and found 285's to be perfect...
Tx
Old Aug 22, 2005 | 09:04 PM
GlennRMK's Avatar
Pro Comp MTs are ok
I think the BFG MTs are a better tire
Mine are sipped, with 10k on them and have some wear.
Expecting 25k or so out of them
Old Aug 22, 2005 | 10:33 PM
torquefan's Avatar
I saw a nifty set of tires the other day, and I think they're the ones for me.
Toyo Open Country M/T. It's a true mud terrain tire that comes in a 265/75R16 or a 285/75R16 both sizes in load range E. The tread is at least as aggressive as a BFG M/T, but the tread elements wrap around the shoulder quite a bit further onto the sidewall. The quality seems great, I installed a set for a customer the other day, and they balanced with very little weight. Anybody using these and have any comments?
Old Aug 24, 2005 | 12:05 AM
Crimedog's Avatar
boosted:
I wanted the Toyo M/Ts so bad! They were backordered til' July so I went with the Pro Comps based on price. The Pro Comps are a very quiet tire, they pick up a little noise once the sipes wear through. No wander or anything with these tires so far. They are a bit sensative, but rotating every oil change takes care of that. As far as treadwear, once the sipes were just about through they have been wearing really slow. They were almost worn through 2,000 miles ago, and I can still see some. I'm hoping they wear a little better now that the sipes are gone, because it took about 5K to wear throught the sipes. My next set is going to be the Toyos though. They should be stocking the 315s now, and I heard that they are a really stiff tire so that's also a plus.
Old Aug 24, 2005 | 02:53 PM
hemertwv's Avatar
OK, I have a 2001 Dually 1 Ton 4x4 Regular cab with a flatdeck, can I run 315's and what mods do I need to do to run it.
Old Aug 24, 2005 | 08:43 PM
boosted:
Thanks for the info I will for sure check out the toyo's
OPepper
Jul 9, 2007 02:31 PM
kev94mx
Feb 25, 2007 11:18 PM
sakisaki400
23
Dec 31, 2006 10:17 PM
taken5875
Aug 16, 2004 12:56 PM
27
Feb 23, 2003 07:56 AM
