Stupid Question but - Tail light replacement
Old Apr 25, 2005 | 05:00 AM
argve's Avatar
This should be an easy no brainer but I ran into problems...
I have a tail light out on the passengers side rear. I have have brake lights but no tail light - assume at this point bad bulb...
So here at work I go out with handy dandy screwdriver and remove the two screws that hold the tail light assembly in from the inside of the bed (had to lower tail gate to gain access). Now I go to remove the housing but it's held fast around the corner... uh oh... Apply a little power and still nothing, it's held fast... is there something I'm missing. The bed has a sprayed in bed liner (linex) but I could see nothing on the inside of the bed nor feel anything that would beholding it. Now it was dark out (3rd shifter) but I had a flash light and backed up to an open bay door so I had the light from inside the building shining out.
Old Apr 25, 2005 | 07:33 AM
2500CTD's Avatar
Not sure about the 95, but guessing they all should be the same, there are clip, that are a tension kinda hold, kinda like a door clip, I got one corner of mine out and slowly pulled along the edges till it popped out. but depending on how easy wet bedliner flows maybe some seeped in and glued the light in??? dunno never seen bedliner when it is still wet.
Old Apr 25, 2005 | 09:15 AM
CarlJensen's Avatar
Just the two screws. As has been said there are clips. Steady pressure should do it, if not you are glued in by bed liner or something else.
Old Apr 25, 2005 | 09:42 AM
argve's Avatar
Got it.
Clips were holding pretty good.
Well I guess the marketing department was right... Dodge defiently different.
Jim Lane
Mar 23, 2013 09:31 PM
bigredbrick
Jul 13, 2008 04:12 PM
Hoss
May 19, 2005 02:28 PM
JKM
Mar 22, 2005 06:29 AM
Boss Hoss 540
14
Mar 19, 2005 12:06 AM
