steering damper removal
Old Feb 26, 2006 | 06:38 PM
MrKen's Avatar
Is there a prefered way to remove the stud attached to the drag link adjuster tube? I am tring to replace the stock shock unit. I have just installed the DSS, and that was easy. Thanks, Ken
Old Feb 26, 2006 | 07:09 PM
rockwithjason's Avatar
You can use a puller like a pitman arm puller. I used a big hammer because none of my pullers fit.
Old Feb 26, 2006 | 07:48 PM
torquefan's Avatar
I usually get on the end of the stud and tap on it with a blunt attachment on an air chisel. Don't do it unless you're replacing it though.
Old Feb 27, 2006 | 10:04 AM
infidel's Avatar
I always use a pitman arm puller, sometimes you need to add some heat and a big hammer to beat on the puller.
Old Feb 27, 2006 | 05:10 PM
pittom's Avatar
I spray with BB blaster then tap(BIG HAMMER MORE LIKE HIT)the top and bottom of drag like at stud then hit stud,stud won't be no good now so youl have to replace it.
tom
Old Feb 27, 2006 | 06:00 PM
runamuk's Avatar
Air hammer/chisel works the best!!
Rick
mercedeezel
13
Oct 13, 2013 12:43 AM
ian515
Apr 16, 2010 02:29 PM
atthepark
Apr 11, 2007 05:30 AM
bishgeo
Dec 31, 2004 07:25 PM
tmiller24
Jan 1, 2004 07:19 PM
