Steering damper removal
Old Apr 8, 2007 | 03:31 PM
atthepark's Avatar
I need some suggestions on how to get the steering damper off my truck. I got the pass. side off no problem, but the drivers side stud is stuck tight. Can this be heated or will or will that damadge the steering arm it is connected to? I am replacing with a new damper. Any suggestion would be much appreciated. Thanks!
Old Apr 8, 2007 | 06:37 PM
Red3quarter's Avatar
When I replaced the steering stabilizer on my 95 dodge I had to put a little bit of heat to the bar the stud fits into. I got it out buy using a couple raps from an impact hammer. I just replaced the one on my 2002 and it came out with one hit with a hammer. I used a rancho steering stabilizer as my replacement both times, what are you using?
Old Apr 8, 2007 | 06:40 PM
infidel's Avatar
I always use a pitman arm puller.
Go buy or rent one.
Old Apr 9, 2007 | 12:30 AM
MrKen's Avatar
I had to use a pitman arm puller for mine too. I was informed to leave the plastic cover off the replacement, something about keeping dirt & water off the movable shaft. I don't know if it makes a difference though.
Old Apr 9, 2007 | 08:03 AM
atthepark's Avatar
Thanks for suggestions. I'll get a pitman arm puller today and let you know how it goes.
Old Apr 10, 2007 | 07:44 AM
atthepark's Avatar
The pitman arm puller worked great.
Now I am trying to get the ball stud out of the track bar so I can install a Luke's Link. Any suggestions would be great. I have the end ground off as per the instructions and the cap and stud still wont come out.
Old Apr 10, 2007 | 09:51 AM
infidel's Avatar
Leave the truck on the ground when replacing the trackbar, otherwise it's under load, the whole axle is trying to shift to the side. Leave the truck on the ground for the entire replacement.
I usually turn the wheel hard left and whack the driver's side end of the bar out with a long drift or steel rod and a hand sledge.
Old Apr 10, 2007 | 11:34 AM
ScottN's Avatar
Sledgehammer.
That thing needs a good whack.
Old Apr 11, 2007 | 05:30 AM
atthepark's Avatar
I got it apart finally. I used a pickle fork on my air hammer to separate the ball joint from the frame. I got ball out of track bar by grinding down the lip and hitting with the air hammer again. It came right apart. The Luke's link is already assembled and I and soaking the other end in penetrant to get the original dmaper off the other end of the track bar so i can replace as well. Should have it back on this afternoon if it doesnt rain.
I have kept the truck in the ground the whole time.
Thanks for all the suggestions. This site is a great money saver!!!!
mercedeezel
13
Oct 13, 2013 12:43 AM
ian515
Apr 16, 2010 02:29 PM
MrKen
Feb 27, 2006 06:00 PM
bishgeo
Dec 31, 2004 07:25 PM
tmiller24
Jan 1, 2004 07:19 PM
