speedo
Old Dec 20, 2009 | 05:01 PM
65dragnet's Avatar
speedo
Is there a cure for my speedometer being off five mph ? (95 2500 auto 245/75-16 tires)
Old Dec 22, 2009 | 11:22 AM
65dragnet's Avatar
Come on , everybodies speedometers are correct ? No way! I suppose I could go up in tire size from the sticker size of 245/75-16 to 285/75-16 . Anybody?
Old Dec 25, 2009 | 11:52 PM
Dinner's Avatar
As far as I know their are two options: A Smarty or the Dealership
Old Dec 26, 2009 | 12:07 AM
torquefan's Avatar
The 95 model year still used the speed sensor on the transfer case. I don't recall there being any ability for software to change the pinion factor for the speedo. You would have to see if there's a different pinion gear available for the speed sensor.
Old Dec 26, 2009 | 01:54 AM
Goofball's Avatar
I would think going up in size to a 265 would be about right... and there are different pinions for the speed sensor. From what i remember there is a color code system to them...
Old Dec 26, 2009 | 04:27 PM
GAmes's Avatar
Is it 5 mph off at all speeds? I have never done this, but read about someone else doing it. Remove the gauge cluster and then the plastic cover that is over the gauges. Secure the shaft that the needle is pressed on to (with bent needle nose pliers perhaps) then pull the needle off. Reinstall the needle with a 5 mph decrease. Mine is off by 2 mph, but I don't care.
Old Dec 26, 2009 | 08:24 PM
littlebuddie's Avatar
Interesting fix GAmes........I may have to try that as mine is reading 5mph off also. But then I am gauging my reading from my Garmin GPS so which is at fault.....?
Old Dec 27, 2009 | 09:05 AM
GAmes's Avatar
With my experience with GPS I'd have to say it is the speedo in error.
Old Dec 28, 2009 | 10:44 AM
Dinner's Avatar
Oops, didn't realize it was a 12 valve, my apologies.
Old Dec 28, 2009 | 04:43 PM
TB1's Avatar
TB1
http://www.high-impact.net/transmiss...peedoGears.htm
Here is a link for the speedo gears and conversion for tire size. I ordered the short gear which is wrong but the gear itself will come off the shaft and can be installed on the stock shaft with some loc tight. It was a dealer part but cheap about $14. I have seen prices for the long one online and they are pricey. The part number's listed are off a little needs a extra 0,but if you were to go to the dealer they could figure it out from the numbers provided. Better option than screwing with the gauge cluster.
TJE
Mar 9, 2011 06:48 PM
Paul S.
Feb 20, 2003 05:29 PM
Monty
Feb 9, 2003 05:07 PM
chdiesel
Oct 31, 2002 03:22 PM
