speedo switch
speedo switch
Hey guy's,I recently swapped a auto tranny out of a 93 D250 into my 91 D350. My question is the 93 speedo unit had three wires.However my 91 harness only has two wires. I purchased a new unit to swap out the 93 unit but they are very different. Is there any way to make the three wire unit work with only the two wires that I have.Any help would be greatly appreciated.THX, C.L. Sharp
Re:speedo switch
Thanks ZONE5AB,I tried that but the sensor's attatch to the tranny in different way's. The 91 has a threaded sleeve that just screws onto tranny.The 93 has a retaining bolt that has to be removed and then the unit can be pulled out.So thats why I was wondering if it could just be wired differently.ThanksC.L.Sharp
Re:speedo switch
The entire unit from the '91 should fit in the '93, there is a fork shaped steel retainer with a single bolt that holds it into the tailhousing. Remove the adapter and speed sensor from the '93 and replace it with the unit from the '91. Be sure to use the same plastic pinion gear that is in the '91 (it simply pulls out of the adapter) and index it according to the tooth count. See pic below.<br><br>
Barryn
Jul 14, 2008 09:30 AM
redramnc
Mar 28, 2005 06:58 AM
