Floppy O/D switch and headlight switch
Old Jul 13, 2008 | 07:54 PM
Barryn's Avatar
I want to do something to tighten up my O/D switch and headlight switch. They are each mounted to tabs on the the bottom side of the dash behind the bezel. The mounting tabs on the bottom side of my crappy dash have broken off allowing those two items (headlight switch and O/D switch) to flop around. (Of course when I started pulling the bezel off to check it out I cracked the dash worse than it already was!! ) Is there a way to tighten these up aside from replacing the dash? If possible I'd like to replace the cracked lens in front of my gauges at the same time. Maybe I should just put it all back togehter and live with it.
Old Jul 14, 2008 | 09:30 AM
infidel's Avatar
Think replacing the dash would be rather pricey.
As for the lens, it's not available separately, you have to buy the entire instrument cluster, pricey again.
Could always try a junkyard, would be easier since gasser dashes are the same.
Personally I'd just see what a little superglue would do and just live with the crack.
mtdoragary
Nov 7, 2013 08:31 AM
jesse123
Jul 8, 2012 09:04 PM
kellypckp
Jan 5, 2011 06:27 PM
Pete Miller
Feb 21, 2008 04:49 PM
jlipskoc
Oct 24, 2005 01:16 PM
