Shift Nob
Old Dec 23, 2019 | 08:55 AM
justpete's Avatar
Shift ***
Good Morning ; Recent Replaced nv4500 / nv5600 , Shift *** has the 4500 pattern on it My ? Tried unscrewing shift *** to replace the 4500 patern to 5600 pattern so far no luck getting it to turn . Has any body done this any tips ?
Old Dec 23, 2019 | 07:05 PM
patdaly's Avatar
Pretty sure at least on the NV4500 the **** doesn't unscrew, have to take the indicator off and a M10X1.5 nut below, see this below.
Old Dec 23, 2019 | 11:42 PM
KATOOM's Avatar
This may help you out... https://www.genosgarage.com/category/shift-****
Old Dec 24, 2019 | 05:06 PM
Peal back the shifter **** cover with a small flat head screw driver, back of the nut under it than spin the **** off.
Then swap the *****.
Or if all you are needing to do is change the cap on the ****, then pry out the 5 speed **** cover and swap in the 6 speed one, without even changing the **** as they are the same the ****.
Old Jan 26, 2020 | 12:38 PM
jimduchek's Avatar
https://amazon.com/gp/product/B006MK2HZ8/ https://amazon.com/gp/product/B006MK2HZ8/
I put this guy on mine years back. Looks stock, feels better than stock and better than those aftermarket ones with set screws that always come loose. They make em for 6 speed civics too. Ton of different options.
Old Feb 1, 2020 | 12:01 PM
SIXSLUG's Avatar
Boil a shop towel and wrap it around the shift ****, wait a minute, then take it off and use a small flathead screwdriver to pop out the cap with the shift pattern on it. The nut is under that. You can mung up the rubber **** if you try to do this at ambient temp....
Old Feb 1, 2020 | 12:55 PM
I like the heated shop rag trick....I am using that next time I spin off a shifter ****.
Old Feb 1, 2020 | 12:59 PM
Fordzilla's Avatar
It might consume less water, time and energy to just microwave a wet rag in a bowl for a minute or so......Ben
Old Feb 6, 2020 | 09:38 AM
SIXSLUG's Avatar
^^^^Not bad idea, up there!!
I replaced my stock **** with a "6" ball I drilled and tapped. It's diesel green and the correct number of gears. You can see it in my profile pics......
n2moto
Apr 22, 2008 02:10 AM
Almo
Mar 8, 2008 01:07 AM
Tate
Aug 10, 2007 05:17 PM
mhuppertz
Sep 3, 2006 12:43 PM
blackboat
Oct 21, 2002 10:00 AM
