Seat belt Light
Old Sep 16, 2014 | 10:23 AM
Sea:\>Drive's Avatar
Seat belt Light
Driver's side seat belt, the light on the dash goes on and off while I'm driving with the belt engaged. If I pull on it slightly it goes off for a second, then back on. Should I just put some contact cleaner in the receptacle where the belt goes, or tear it all apart? Anyone had this? I've tried jumpering the plug on the belt but the light stayed on, jumped or not.
Old Sep 17, 2014 | 06:19 AM
DIESELWRKS's Avatar
you can try cleaning the contacts but it can also be that the connection piece when putting in the seat belt latch could be worn out. I too have the issue mine started the same time as my passenger window swith on the driver side started to not go down but only up. I'm tempted to just pull the dash and remove the bulb in the dash that is not hard to do. Out of sight out of mind.
Old Sep 17, 2014 | 06:21 AM
HMX-1's Avatar
Check the electrical connector under the seat. The wife's '06 was doing the same thing, sometimes it would flicker, sometimes it would just stay on. It was corroded, so I cleaned it up and used some di-electric grease on it. Problem solved.
-Kris
Old Sep 17, 2014 | 09:40 AM
Will do, I expect certain things with a 13 year old truck and don't really need the light as I always wear my belt, so now I have a few plans of attack. Thanks!
Old Sep 17, 2014 | 10:13 PM
SIXSLUG's Avatar
Mine was acting up around 65K IIRC. the dealer sprayed some lube in the latch and it went away for a while then came back.
replace the latch.....
Old Sep 24, 2014 | 11:20 AM
Anyone know the part number for the tan latch? I've been hunting online but no one seems to have accurate pictures to ensure I get the right part? Thanks for anyone that can provide it!
Edit: Never mind I found it through some ninja web searching: 5GT65RK5AD if you have the Tan interior (called camel) for anyone that may need one.
Old Sep 25, 2014 | 06:00 PM
SIXSLUG's Avatar
Buy two!!
Old Oct 3, 2014 | 12:57 PM
Really? They are $75 bucks...and this one did last 13 years...
Old Oct 4, 2014 | 02:45 PM
SIXSLUG's Avatar
I was thinkin that if they still make them and you will keep your truck as long as I plan on keeping mine, I could buy the other one from you if I needed one!
Old Oct 6, 2014 | 10:26 AM
Good thought...but those new 1/2 tons w/diesel are rated to tow more than my old girl is. Hmmph!
scow1
Mar 18, 2011 04:14 PM
justagoodolboy
Mar 7, 2011 08:25 AM
cmac
Nov 30, 2009 11:11 AM
Johnny RAM
Sep 24, 2008 07:40 PM
92red
Jun 6, 2008 09:21 AM
