Seat Belt length
Old Dec 24, 2004 | 12:48 PM
BUFF's Avatar
Angry Seat Belt length
Did the seat cushion foam upgrade and now my seat belt is so tight that I can barely get it fastened
Is there a way to lengthen the belt or can I get a longer belt from Dodge or aftermarket
Have to do something because this is driving me crazy!!
Old Dec 24, 2004 | 01:19 PM
apache's Avatar
If im not mistaken you can get extenders from Dodge or the aftermarket. Sorry I dont have any links.
Old Dec 24, 2004 | 01:47 PM
BigRobin's Avatar
buff, there is a difficult but free way to make the belts fit better, at least thats what my wife tells me.
Old Dec 24, 2004 | 02:20 PM
tool's Avatar
I think that part number is #0000001 From Jenny Craig right?
Old Dec 24, 2004 | 02:27 PM
BUFF's Avatar
Yep...I am aware of that way also....my problem is that I can resist anything but temptation
Old Dec 24, 2004 | 06:23 PM
infidel's Avatar
Used to be any dealer will give you extenders for free, not sure nowadays.
Old Dec 25, 2004 | 11:16 AM
Eskimo's Avatar
Re: Seat Belt length
Originally posted by BUFF
Did the seat cushion foam upgrade and...
After just spending 10 painful hours in my seat, you're certainly got my attention on this... do tell!!
P/O was around 300lbs, so my seat is worn plum out.
Old Dec 26, 2004 | 02:10 PM
BUFF's Avatar
Re: Re: Seat Belt length
The seat cushion upgrade is really simple...4 bolts to take the bottom of the seat off, couple of spring type clamps to remove the bottom springs and wire support, add about 2" of foam padding ( I used 1/2" heavy carpet pad glued together to get to 2'"), install a piece of old carpet back side against the wires, re-hook the spring clamps and re- install the seat! Takes about 1/2 hour to 45 minutes to do the entire job!
Man....what a difference it has made in my comfort on long trips
Dave
Old Dec 26, 2004 | 02:12 PM
BUFF's Avatar
Really
Can anyone verify that this is still the case? I need something to fix this problem now!!!
Dave
Old Dec 26, 2004 | 02:40 PM
natstayl's Avatar
I had to pick up two extensions for the family car for when we haul a larger family member. They were free, ask your new truck dealer. They're dealer stock item only and probably only available in black. Equal protection for the masses; no matter the race, creed, gender, religion, size, etc. Don't want to imply that it's an extra cost option, else might be a lawsuit I was told. The only decision I had to make was if we needed the 9" or the 15" extensions. Seriously!
Nat
Old Dec 26, 2004 | 03:50 PM
BUFF's Avatar
Nat
Thanks Nat!! I'll call the dealership tomorrow.
DodgeDiesel61
Jan 26, 2019 07:45 PM
justagoodolboy
Mar 7, 2011 08:25 AM
Johnny RAM
Sep 24, 2008 07:40 PM
92red
Jun 6, 2008 09:21 AM
DJ
Apr 17, 2003 11:48 AM
