Rustproofing door panels
Old May 26, 2006 | 07:36 AM
big jimmy's Avatar
Is there a great product that will stop/prevent rust in areas like the door seams along the rocker panels and the bottom of the tailgate?
Even here in dry Colorado I am seeing rust develope in these areas. I don't want to sand, prep, tweek, fuss with, or anything else to stop the rust. What I want is something that will penetrate the areas but won't wash off after a few months.
Thanks
Big Jimmy
Old May 26, 2006 | 07:50 AM
Derek_J's Avatar
POR 15
works great used it on one of my old wheeling rigs
wont wash off ever
http://www.por15.com/
Old May 26, 2006 | 11:36 AM
jkretzer's Avatar
i second the por15, put it on my snow plow frame and mount. here in a month i am going to take apart the doors and coat them as well. josh
Old May 27, 2006 | 05:00 PM
XX4me's Avatar
You say you're going to take apart the doors?
What part are you painting?
Old May 27, 2006 | 06:41 PM
kd460's Avatar
Good old fashion oil! It wicks up hill (flows against gravity) seeps into tight places like the door skin lip that is folded over the inner door panel, and it displaces moisture. Stops the metal from oxidizing (rust) as long as it is present.
Brush the oil along a seam like I just described, let it sit for awhile (overnight is best), and wipe off the excess. I like it cause it goes in the same spots that the water goes into.
You can squirt it into drain plug holes in your doors, rocker panels, fender wells, tailgate, etc. It will wick into all the nook and crannys.
Yes it will drip for a day or two, but it works really well. There are even shops that will do this for you, and they actually add a wax to it to make it thicker. They apply it warm, and then it sets up a little so it don't drip.
There are DIY products out their as well one that omes to mind is waxoyl. I even found a recipe for it once on google.
I do my truck once a year, seems to be working well. KD
Old May 27, 2006 | 09:10 PM
kawi600's Avatar
I repaired a pair of doors I got for cheap.. welded in a patch for the door skin and the sill and glassed over the repair on both. What I did was to just spray the heck out of the inside of the sill and skin with an etching primer. You could use a zinc primer as well. If I hadnt already had the paint out Id have used a phosphoric acid treatment like 'must for rust'. That will etch the metal and create a layer of reacted chemical that doesnt rust. Good for parts that dont see rock chips and such, like the inside of a door or a repaired rocker panel.
You could spray oil or paraffin lube in there to repel the water, but once you do that it will be that much harder to do bodywork inside later on.
If you look at how these doors rust, it always starts in the folded area where the skin goes around the sill. Id go in there with some silicone sealant and try to keep the water out altogether.
Old May 27, 2006 | 10:25 PM
torquefan's Avatar
There's a product called "Fluid Film" that is a very good penetrant and protectant. It comes in aerosol and liquid.
Old May 28, 2006 | 11:57 PM
kd460's Avatar
Not to sure about the silicone. It is acidic untill it cures, and talk about painting, paint don't like silicone. If you seal that lip, it will hold even more moisture as water still gets inside the door, and the silicone will just help hold it in.
The oil can be stripped or cut with any solvent, so if repainting, just clean it with the solvent, then follow up with grease and wax remover. KD
Old May 30, 2006 | 06:50 AM
SHARPMACHINE's Avatar
I've been using oil and or chain lube for motorcyles. The chain lube is supposed to pull into tight areas and stick good. I am not sure how much it is helping though?????????
Bobcat698
Jul 28, 2005 01:31 PM
javabeanjava
Dec 7, 2003 10:33 AM
tarpilot
Aug 2, 2003 11:26 PM
Drafter
13
Feb 5, 2003 10:28 AM
shortfieldbreak
Dec 3, 2002 07:57 PM
