Running lights staying on, having to pull relay switch
Old 11-11-2018, 07:48 AM
2001dodg's Avatar
Just recently the daytime running lights have been staying on after turning the switch to OFF. Sometimes I could slam the door hard enough and they would turn themselves off but now that don't work. I have to pull the relay switch under the hood to turn them off. Any ideas?
Old 11-11-2018, 09:24 AM
cougar's Avatar
Could be the headlight switch or it could be the relay. You can swap relays with any in the fuse box and see if that does it. You can also use a volt meter to test the pins were the relay plugs in. Only one should be hot. If you have 2 it's the switch.
Old 11-11-2018, 03:00 PM
SIXSLUG's Avatar
Search "DTRL" in this section.....
Old 11-12-2018, 11:51 AM
torquefan's Avatar
That is generally caused by an internal failure of the daytime running light module. Small black box on the driver side wheel well, close to the master cylinder.
moparguy
14
09-28-2017 04:58 PM
300stw
08-09-2010 06:52 AM
Banzai Bob
02-24-2010 12:24 AM
Quick Reply: Running lights staying on, having to pull relay switch
