Replace cracked dash
Old Feb 6, 2015 | 06:04 PM
LDoyle's Avatar
I have given up hoping it would become a recall based on a safety stand point ( airbag propelling bits of plastic like bullets ) and I have decided I would have to replace it myself . Can anyone who has done it give any hints or tips on how to make this go smoothly ?
Thanks
Old Feb 7, 2015 | 07:43 AM
high bid's Avatar
Many of tips, ideas and solutions....just use the search function and I'm sure you'll find good info.
Old Feb 10, 2015 | 07:12 AM
VADSLRAM's Avatar
LMC is a great source for a new dash. I replaced mine through them.
Two things you should also get at the same time are the the re-enforcement washers and the plastic blocks that are on the firewall where the dash screws in to.
Truck Parts and Truck Accessories
I haven't found a good souce for the anchor nut. I made my own
But this might work
Chrysler Cowl Screen Nut #8 Screw Size
First unbolt the steering column, then remove all the screws by the windshield into the firewall, then there is a bolt on each side of the dash(by the Ebrake pedal) and the pivot in the center of the dash now the whole thing will tilt forward. Then you have to play contortionist to remove the screws that hold the dash to some supports, They are facing backwards and just under the front lip of the dash. Mine were simple since the only pieces that were still on the truck were where the screws held them in.
Old Feb 11, 2015 | 08:57 AM
onehitwonder53's Avatar
help
actually just watched car fix where they showed this. you need to drop the pass. side air bag. there are 4 bolts behind that. and also the say u need to drop the steering column because there are screws that are facing backwards from the very front by the windshield, so after droping the steering column the whole dash will roll forward to let u access these bolts..
Also don't forget to discount batterys when screwing with the airbag. wouldn't want that to go off.
Old Feb 11, 2015 | 08:53 PM
LDoyle's Avatar
Thanks for the replies guys . Not quite ready yet , just making a game plan and need to know what I`m up against .
Old Feb 13, 2015 | 08:16 AM
flounder's Avatar
anchor nut
Im in the middle of dash replacement and have found my nylon anchors on firewall are cracked and can't find any??any help would b greatly appreciated!! Thanks so much
Old Feb 13, 2015 | 04:38 PM
LDoyle's Avatar
Seems like I saw those somewhere .. Maybe LMC or it may have been Geno`s Garage . It may have even been in a post I read somewhere , so I guess I`m not much help . Sorry
Old Feb 13, 2015 | 10:30 PM
flounder's Avatar
nylon grommet nuts
Wow just reread thread and realized vadslram made a suggestion on this? I couldn't find the exact size of that one but ordered some anyway.I will let you know if they work in meantime im still searching!Thanks
Old Feb 24, 2015 | 11:39 AM
flounder's Avatar
just got the nylon gommet nut previously mentioned and no go!wa to small. I cant believe something so simple is holding me up?? any help or suggestions will be greatly appreciated!Thanks
Old Feb 27, 2015 | 03:16 PM
flounder's Avatar
got it
Went to dealer in Richmond today and they hooked me up!part #6504485! All parts guys are not created equal!!!
Old Feb 27, 2015 | 08:54 PM
DIESELWRKS's Avatar
a very true statement.
93 high hopes
Apr 20, 2011 07:06 PM
NoSparkplugs
17
May 17, 2009 10:36 PM
klx650a2
Apr 20, 2009 05:25 PM
CUDANUT
Feb 16, 2008 11:42 PM
WVPANHANDLER
Feb 1, 2003 08:23 PM
