questions about headights?
Old Jan 29, 2011 | 05:12 PM
  #31
Silver R/T's Avatar
http://cgi.ebay.com/ebaymotors/99-01...Q5fAccessories
Old Jan 29, 2011 | 06:23 PM
  #32
novahauler's Avatar
Could i be that I ordered the wrong harnesses? I ordered one of the 55-9505 and one of the 55-9506. Maybe I read it wrong and should have ordered 2 of the 55-9505? Im just throwing out options here. See below.
http://www.lmctruck.com/icatalog/de/full.aspx?Page=45
Old Jan 29, 2011 | 07:21 PM
  #33
Silver R/T's Avatar
This is the one you need for sport headlight upgrade
http://suvlights.com/product_info.php?products_id=116
Old Jan 29, 2011 | 07:45 PM
  #34
oldblues's Avatar
Exclamation
hi
i do not have sport lights , but i did install a hd harness and had a similar problem .
i ended up switching the two wire locations on the right side headlight only !
there are 3 wires in the socket and i think i switched the two outer ones and it cured the problem .
the connectors had to be Very carefully removed from the socket and reinstalled in oposit positions ?
maby this will help ?
ps i read the add and think you got the correct harness ???
Old Jan 29, 2011 | 09:54 PM
  #35
novahauler's Avatar
Note to others getting ready to do this....if you are upgrading to sport lights on a non sport model and you decide to get the LMC harness, do not get the 55-906, get 2 of the 55-905. Save yourself the headache. Before I read oldblues post, I had it figured out. I had to change the order of the wires around on the 55-906 to match what my truck has. Now I have to get the right relays, because they are different also, and I should be good to go. Still can't get it to work with the fog lights, but that may be because I don't have all the correct relays.
Anybody know where you can get some relays? I am not sure if my local auto store will have it or not, but plan on checking tomorrow.
Old Mar 5, 2011 | 08:07 PM
  #36
novahauler's Avatar
Finally got a chance to check on the fog light problems and I did the jumper wire mod in the fog light relay and that solved the problem. Now I have fog lights on both high and low and all 4 lights working on high and low as well.
Old Mar 23, 2011 | 01:04 PM
  #37
slayerfish's Avatar
Thx for the link. I cant wait to see at night again.
popeye4wheeler
Jan 30, 2011 06:24 PM
Clucker
22
Sep 24, 2009 09:34 PM
harlydan
Jan 30, 2008 02:55 PM
GR40RCapri
Oct 30, 2007 09:37 AM
gman07
Apr 15, 2006 08:32 PM
