power seat help!
power seat help!
after my romp in the mud at the nor. cal. party in december. my seat adjustment buttons etc dont work right. my lumbar switch doesnt work at al!
do they sell a new unit. or do i have to replace the whole darn seat?
If it's one of the motors you have to replace the whole lower seat frame. More than likely it's in the switch(s). I'd get a test light and start checking the switches. Make sure you getting power to them. Then toggle the switch, is there power on the other side of the switch when operated? If your not getting power to the switch(s) go back to the fuse panel and start there. If you do have power go to the motor(s) and check for power there. I had to do this on my fathers truck when one of the motors conked out.
Good luck
Good luck
Repairable Motor
I was able to repair one of my seat motors that stopped working after they got wet in a car wash (the window was open a small amount)
If it turns out to be a bad motor, It can be repaired.
You'll need some torx bits to unbolt it out of there and remove the bottom cushion to get easy access to the motors (I discovered that after the fact)
Hope you find the problem.
Here's the post: https://www.dieseltruckresource.com/...d.php?t=153846
its not a lack of power to the motort or switches.. the switches them selves have had 4 years of mud. rain etc. i drive with my window down just about everywhere. there pics of my left side with 2 inches of mud from offroading etc.
so i just need to know if theres a way to not replace the whole seat, bottom part of the seat. knowing dodge. ill need to do that. the individual switches are not serviceable . its a giant 4 switch box!!
thanks
thanks
your right! i called the dealership yesturday, while having some offtime. i can buy the whole assembly with all 4 switches. 87$$$ well i guess its worth having that lumbar support while on a 16 hour trip..
thanks everyone!
hopefully its not too much of a pain in the butt
thanks everyone!
DezertBum
Mar 10, 2010 03:00 AM
Common
Jul 27, 2006 09:46 AM
bigsam
Aug 20, 2005 09:29 PM
