OEM towing mirrors
Old May 5, 2005 | 10:40 AM
DodgeDrivinAggie's Avatar
OEM towing mirrors
anyone know where i can get a pair of the large, fold out tow mirrors. Dealer wants around $500 a piece. i need electric, heated.
thanks
Old May 5, 2005 | 11:04 AM
Johnny's Avatar
Your best bet would be to do a search of wrecking yards. When I had to replace the driver's side on my truck, the local dealer wanted $300. It comes as a whole unit, the arm and box. At the time I asked if the new heated mirrors would fit, their answer was no. The base is different enough not to match.
Old May 5, 2005 | 11:07 AM
latitud_rt's Avatar
You can't get factory type tow flip out mirrors for 2nd gen with heat/electric option. You have to make hybrids yourself, 3rd gen mirrors matched to 2nd gen bases. Although there are lots of aftermarket mirrors available.
Old May 5, 2005 | 02:52 PM
mkubacak's Avatar
If you don't want to do the 3rd/2nd gen hybrid, check out the **** mirrors. I have a pic in my gallery of a 3/4 front view.
Old May 5, 2005 | 03:46 PM
thanks for the direction, gentlemen. i have aftermarket mirrors right now, but the glass vibrates so much you get sea sick trying to look behind you. the 3rd gen/2nd gen hybrid would work for me. now to see if i can round up the parts at a reasonable cost.
Old May 5, 2005 | 06:33 PM
1320's Avatar
****/best top (same mirrors) are great. My 98 has heat and power, bolted right on for just over 300.....and when extended are out about 1 inch further then the best oem mirrors which helps see around my big gooseneck.
Old May 6, 2005 | 08:26 PM
KennyG's Avatar
I have the extendable **** heated , electric mirrors. "Fantastic!!!" They extend 4 1/4" ...work great and look great!!! $349 @ Genos!
http://198.104.149.53/CoastalData/sh...ID=785&CATID=1
Old Jun 27, 2005 | 11:05 PM
ram29's Avatar
I just bought a set of the 3rd gen towing mirrors for $115. What all is required to put them on my '97?
Old Jun 28, 2005 | 08:01 AM
mkubacak's Avatar
You also need a set of 2nd gen towing mirrors. Then swap the bases. I have not done it, but there have been a few threads on here describing the process. I know you need to watch out for a spring. Do a search and you will find all the details.
SKATERHAULER
Oct 2, 2013 06:34 AM
Shaun Cockran
May 8, 2012 05:52 PM
BAJA MAN
Nov 21, 2006 05:49 PM
rocketguy
13
Feb 9, 2006 03:46 PM
fxallen
Jun 8, 2005 10:28 PM
