OEM Third brake light wire?
Old May 23, 2023 | 02:17 PM
APD's Avatar
APD
I want to wire up a third brake light on my contractor cap for my 1997 2500.
The internet says there should be a factory wire provided for this sticking out of the harness near the spare tire.
I have dropped the spare tire but don't see anything.
Can anyone confirm that it exists on 1997 models? I have a third brake light on the cab.
Old May 24, 2023 | 09:48 AM
texasprd's Avatar
I haven't even glanced at it in so long, but I recall a 7-pin trailer connector in the bed of my '96. I assume that is OE. Does your '97 have that? I don't know if that connector is connected from the factory, though. Check your PMs
Old May 24, 2023 | 05:27 PM
APD's Avatar
APD
I have a 7 pin, not OEM, but that doesn't matter....you cant take brake lights directly from the 7 pin because it is shared with the turn signals and it would flash when you use turn signals. If I could do that I would just take it from the brake lights.
There is an extra wire on some trucks, specifically for a third high mount brake light, called CHMSL (center high mount stop lamp). Some trucks have it, apparently mine doesn't.
But I sorted it out and ran a wire directly from the brake switch at the pedal. Its the white/tan wire if anyone cares.
Old May 24, 2023 | 08:08 PM
texasprd's Avatar
Good point - I didn't think that through far enough
Old May 25, 2023 | 12:01 PM
Danavilla's Avatar
Here is what I gleaned from the service manual wiring section. You can tap into the WT/TN brake wire at C203 located near the drivers side firewall.
Old May 26, 2023 | 10:46 AM
annywood's Avatar
There is an extra wire on some trucks, specifically for a third high essay mount brake light, called CHMSL (center high mount stop lamp). Some trucks have it, apparently mine doesn't.
I understand what you're saying, but I actually have a different perspective on this issue. It does matter whether your 7-pin connection is OEM or not because it can affect the wiring configuration and what functions are available. I mean yeah, while it's true that the brake lights are typically shared with the turn signals on a 7-pin connector, there are ways to separate them to prevent the flashing issue. One common method is using a relay or diode setup to isolate the brake light circuit from the turn signal circuit. For example, this allows me to tap into the brake lights without interference from the turn signals)
Old May 28, 2023 | 01:18 PM
SIXSLUG's Avatar
My FSM says white wire with tan tracer for 2001....
Kurt
Old Jun 2, 2023 | 05:13 PM
APD's Avatar
APD
Ok, but what I was asking about was the factory wire that eliminates the need for any diodes/relays/logic controller.
Some trucks have an extra wire in the harness labeled "CHMSL". The wire is not connected to anything at the rear, and it comes out of the harness near the spare tire. That wire is specifically for a Center High Mount Stop Lamp that is found on caps and campers.
Now it may be possible that the extra wire only exists on trucks with factory 7 pin trailer connectors....that's what I was trying to figure out. Because my truck doesn't have the extra wire and some do.
Kerley
Oct 28, 2018 08:02 PM
CZSteve
May 10, 2011 09:37 AM
SpectreBoy
Feb 20, 2011 12:55 PM
bumpytruck
16
Jun 30, 2008 02:17 PM
MR. GADGET
Feb 24, 2003 10:24 PM
