No Turn Signals or Hazards
Old Jan 19, 2003 | 04:23 PM
HitTheRoad's Avatar
We have a 1999 Dodge 3500 Diesel. When hooking up someone's boat to our truck we lost our turn signals, hazards and taillights. We checked all fuses in the side panel and under the hood and replaced 2. Now we have taillights but still no turn signals or hazards. What else could be wrong? :'( Thanks for your help & suggestions......
Old Jan 19, 2003 | 07:38 PM
Thomas's Avatar
Re:No Turn Signals or Hazards
What year is the truck?
Old Jan 19, 2003 | 07:40 PM
pappyman's Avatar
I have had both flashers burn out because of miswired trailers (I check my turns using the 4 ways)...besure the underhood fuses are good and seated correctly in the power distribution box
Old Jan 19, 2003 | 09:50 PM
Thomas's Avatar
I think you'll find that your 1999 Ram has a single combination flasher rather than the two some have suggested. It is not a conventional flasher but rather a "smart" relay with integrated circuitry. The service manual states that it can't be tested with conventional automotive test equipment. As far as I know it is available only from the dealer. It would be good to try a known good flasher before buying one. If you know anyone with a 1999-2002 Ram the flasher should be the same. You'll find the combination flasher behind the door at the left end of the dash.
Old Jan 20, 2003 | 10:20 PM
HitTheRoad's Avatar
Thanks everyone for your help. We got a new flasher from the dealer and they also found burnt wires that needed replaced or they would have burned out the new flasher too. What a mess! Everything's ok now though so we can "Keep On Truckin".......... Thanks again for the help! 8)
peckens
Dec 20, 2012 07:24 PM
DodgeCowboy
14
Nov 12, 2012 11:42 PM
skidooer76
Feb 13, 2010 08:08 PM
diesel_pwr
May 15, 2008 10:52 PM
boehunter49
Nov 28, 2002 06:41 PM
