No blinkers
Old 06-14-2018, 11:44 AM
Sir_Timn's Avatar
No blinkers
(1994 ram) My blinkers stopped working today while driving. I googled it and found alot of common stuff but non fixed my truck. I checked both flasher relays. My hazards work fine so i swapped the relays and still no blinkers. I was thinking it would be the lever but i can still use my high beams and wipers on it (could be that but i dont wanna rip my steering colom apart unless in sure) i also checked all fuses regarding my indicators. Im not sure if this is related but my lowbeams still work but the dash light doesnt turn on when they are... please help, thanks!
Old 06-14-2018, 12:32 PM
Sir_Timn's Avatar
*fixed*
I guess the relay swap worked... it didnt the minute i swapped them but after a shower i tried it and it worked fine..... still gonna buy new ones since these are most likely relays from the factory
Old 06-14-2018, 03:51 PM
AlpineRAM's Avatar
I'd also take a look at the wiring loom snaking along the steering column. (Sometimes a connector gets partially pulled apart and causes random problems)
Old 06-24-2018, 11:45 AM
SIXSLUG's Avatar
Also, check the wiring in your trailer connector if you have one....the terminals can corrode and cross up voltage to each other
AlpineRAM (06-24-2018)
Old 06-24-2018, 04:13 PM
AlpineRAM's Avatar
Yep, I forgot that "classic", made me scratch my head more than once!
roberts11260
12-01-2006 07:06 PM
Ritler
03-21-2005 07:12 PM
jazz_kt2000
08-17-2004 04:45 PM
dsljunkie
02-23-2004 02:54 PM
CRobey4393
01-03-2003 08:29 AM
Quick Reply: No blinkers
