No blinkers
(1994 ram) My blinkers stopped working today while driving. I googled it and found alot of common stuff but non fixed my truck. I checked both flasher relays. My hazards work fine so i swapped the relays and still no blinkers. I was thinking it would be the lever but i can still use my high beams and wipers on it (could be that but i dont wanna rip my steering colom apart unless in sure) i also checked all fuses regarding my indicators. Im not sure if this is related but my lowbeams still work but the dash light doesnt turn on when they are... please help, thanks!
*fixed*
I guess the relay swap worked... it didnt the minute i swapped them but after a shower i tried it and it worked fine..... still gonna buy new ones since these are most likely relays from the factory
I'd also take a look at the wiring loom snaking along the steering column. (Sometimes a connector gets partially pulled apart and causes random problems)
Also, check the wiring in your trailer connector if you have one....the terminals can corrode and cross up voltage to each other
Originally Posted by SIXSLUG
(Post 3349909)
