01 CTD blinkers an flasher no longer work
Old Nov 30, 2006 | 04:23 PM
roberts11260's Avatar
I replaced the 40 dollar relay for the signals/hazards. it would just barley work then stopped again..
The volt meter on the dash has been going up an down for about 3 weeks, not sure if that has something to do with it.
My truck is how I make a living I transport motorcycles and this close to X mas its going to really be bad if I cant get it going again.
please help
Old Nov 30, 2006 | 05:24 PM
John Faughn's Avatar
I would start looking at the rear tail lites , trailer wiring if you got it , sounds like a short , every once and a while I've seen the connector spots on the lite bulbs melt and get power & or ground going where you do not want it to go , remove all the lite bulbs in those circuts to see if there is anything amiss.
Old Nov 30, 2006 | 09:13 PM
ok i will deff try that.
thanx
Old Nov 30, 2006 | 11:28 PM
Just got it squared away.
the problem was a screw inside the trailer plug became loose and was connecting the yellow and ground.
I spent 40 bux at dodge for a new haz flasher and blew it then spent 8 bux on fuses that I blew and another hazzard flasher from auto zone for 12.99
Ill be back on the road first thing friday.
just another few months with this 01 CTD before I buy a new 07
Old Dec 1, 2006 | 07:06 PM
Some times its the simple things .
Rotten
Jan 1, 2013 01:55 PM
roughstock
Oct 2, 2008 05:43 AM
Ritler
Mar 21, 2005 07:12 PM
dsljunkie
Feb 23, 2004 02:54 PM
CRobey4393
Jan 3, 2003 08:29 AM
