Need Some Help, Please!
Old Jan 14, 2007 | 05:48 PM
CANADAIR's Avatar
I just had my 97 12v towed to my house. I am a little stumped on what the problem might be, so if anybody has some insight, I would greatly appreciate it.
I live in Denver, work the night shift. It was about -12 the night before it died. I started the truck in the morning after it was outside all night, fired up just fine. I let it warm up for about 15 minutes, and then drove off. About 12 miles down the road the engine lost power, and then stalled. Being an idiot, I did not have fuel additives in the fuel. I put additives in the fuel after it died, changed out the fuel filter, and then the truck started again, ran for about 2 minutes and then died again. I tried to bleed the fuel system through the banjo bolt on the fuel filter, and all I get are bubbles, no solid stream of fuel after priming the transfer/lift pump. I had just replaced the lift pump about two months ago. Could I have a cracked fuel line letting air in the system, or maybe parafin wax built up in the pre-filter blocking fuel flow?
Thanks in advance!!!!!!!!!!!!
Old Jan 14, 2007 | 05:50 PM
Geico266's Avatar
Your fuel is gelled up. Adding additives after the fact is iffy at best because it has gelled and it won't mix properly. There is a product called Power Service 911, (red bottle). Get it at any truck stop, Walmart, ect. Follow directions on the bottle.
You need to get Power Service 911 into your fuel system and filter housing. Should fire right up.
Never run a diesel without addatives in the fuel. Even in the summer.
Old Jan 14, 2007 | 05:51 PM
CANADAIR's Avatar
I will do that, thanks!
CTD2001's Avatar
sounds like gelled fuel
Old Jan 14, 2007 | 07:44 PM
dssimecek's Avatar
Don't some truck put #1 diesel fuel in for cold weather?
Old Jan 14, 2007 | 08:37 PM
TIMMY22's Avatar
you can use a heat gun. better yet, cover the front of your truck with a tarp and put a kero bullet heater under it for a hour or so. this will thaw the jell in the lines.
Old Jan 15, 2007 | 05:41 PM
CANADAIR's Avatar
I could not find Diesel911 anywhere in Denver, had the truck plugged in all day, primed the fuel filter again, and it started right up and continued to run. Thanks for steering me in the right direction, I was ready to throw some parts at it. It also helped that it got to a hot 18 degrees today, lol.
Old Jan 15, 2007 | 06:50 PM
plow's Avatar
Plugging one in does generate enough heat to keep fuel lines and filters from gelling, I notice when I plug mine in that the cab is alittle warmer than usual, but no need to lately its been almost 70* here.
Mini_Donkeys
Apr 19, 2007 12:21 PM
SuperiorRam
Mar 15, 2007 03:10 AM
TxDiesel007
Nov 29, 2006 12:08 PM
SilverHoss99
Oct 31, 2005 07:22 PM
JKM
Mar 4, 2005 03:33 PM
