need some electrical help
Old Jan 21, 2005 | 10:22 PM
cr25ovet's Avatar
just bought a 1995 dodge ram 3500 dually. i already have a 2004 3500 but needed a work truck for the farm. now i have some prolems. the passenger side window won't go up. the motor won't turn. not from the driver side or passenger side switches. also when you switch on the headlight the windshield wiper start at the same time. any ideas? thanks for all the help in advance!
chris
Old Jan 21, 2005 | 10:46 PM
BoostdCTD's Avatar
I never heard of the wipers with headlights like that but I do know that the headlight switch is pushed to the limit and occasionaly will melt itself.
Old Jan 24, 2005 | 01:57 PM
Lil Dog's Avatar
Sounds like some bad grounding.. I am not sure on the locations of the grounds in the cab, but the others to the frame etc should be cleaned up.
As far as the window, check for power at the switches and the motor. That will tell you what needs replacing. It may be a bad ground there as well.
Gutterslug
Mar 21, 2008 07:05 PM
manureman
Feb 27, 2007 07:56 PM
TxDiesel007
Nov 29, 2006 12:08 PM
SilverHoss99
Oct 31, 2005 07:22 PM
JKM
Mar 4, 2005 03:33 PM
