Fine metal particles in fuel filter
Old Jan 23, 2005 | 11:32 AM
kd460's Avatar
Was doing some PM, and pulled my fuel filter cannister after draining it. Noticed a little bit of what looks like fine metal particles in the residual fuel ( the stuff that did not drain out).
Stupid me, I did not think to check it with a magnet before I dumped it. It was a small amount and very fine. Not enough to leave any build up. I just noticed sparkles in the fuel.
Also found a small amount of water in there as well, but that is probably from me pulling the truck into my heated garage about once or twice a week for the entire night.
So any ideas? It is (most likely) the original lift pump. Hopefully not anything worse. Kevin
Old Jan 23, 2005 | 01:10 PM
infidel's Avatar
I've always found a small amount of brass particles in any 12 valve filter I've disected.
Figured it comes from the lift pump.
Old Jan 23, 2005 | 04:21 PM
kd460's Avatar
Thats my thinking as well. Not sure what color, but it looked silver. I guess I'll keep an eye on it. Thanks for the reply, Kevin
Old Jan 23, 2005 | 07:42 PM
ArcticWolf's Avatar
It could also be contamination from the filling station you're using - I had this problem once. I changed the fuel filter and started using a different station and haven't had anything like that show up since.
Old Jan 23, 2005 | 10:48 PM
Hemi Cat's Avatar
There aren't many places that small metal particles in the filter can come from. It's doubtful it's coming from the tank, most likely it's coming from the lift pump. It has one way check valves that will hammer out.
Old Jan 23, 2005 | 11:40 PM
wings's Avatar
That's exactly what happened to my truck. The lift pump passed away and the filter caught the particles. It's amazing how well the filter works. vp-44 still going strong 40,000 later.
check the lift pump.....why bother it gone, just get another...spend 30 minutes installing and move on.
bentwings
Old Jan 24, 2005 | 12:23 AM
Geico266's Avatar
A FP guage would tell you what is going on with your LP. Waiting until you change your fuel filter is not very efficent in preventing IP failure.
Sounds like the fuel filter did its job.
Old Jan 24, 2005 | 06:23 AM
Smokee's Avatar
Perhaps the filings are from the aluminum pump nozzle. s
Old Jan 24, 2005 | 09:40 AM
infidel's Avatar
All you 24 valve guys are answering with LP suggestions that don't really apply to kd's 12 valve.
Old Jan 24, 2005 | 02:47 PM
kd460's Avatar
Yep, 12 valve, but thanks anyways. Kevin
13ALPHA
24
May 4, 2012 01:15 PM
jdddually
Jun 16, 2011 09:18 PM
mattmanj2001
Aug 19, 2010 08:18 PM
Twodiesels
Jun 25, 2007 10:34 PM
