HP difference between 99 and 01 auto
Old Oct 2, 2005 | 11:17 PM
1qckdodge's Avatar
I have been searching for over an hour and cant come up with a answer, I have a 99 and a good friend just purchased a 01 auto, my truck has exhaust and drop in filter, and 285s, his has an just a drop in filter and 265s, when driving the 2 trucks they feel very similar, then when you get in the throttle hard and boost comes in the 01 feels like it revs a lot quicker and the boost hits harder, mine doesnt feel the same, it runs good and has a good amount of pull on the highway but his is nice dand peppy, can the difference be the hy35 vs the hx35, and if so does that signify the different power levels, sorry to rant.
Old Oct 2, 2005 | 11:58 PM
hotdram's Avatar
Check this link here Click here
This page has links to the specs for each year.
~Rob
Old Oct 3, 2005 | 12:01 AM
hotdram's Avatar
Looks like a 99 Auto has 215 HP/ 420 Tq and the 01 Auto has 235 HP/ 460 Tq.
~Rob
Old Oct 3, 2005 | 01:09 AM
Diesel Weasel's Avatar
http://www.dodgedieseldatabase.com/stock_hp.htm
Old Oct 3, 2005 | 07:00 AM
1qckdodge's Avatar
Those are some of the links I found, I was more tryin to figure out what was causing the difference, is the hy35 giving the 01s that bit more hp and tq? the compression stayed the same for the 2 years, only thing I might have found is that the newer model or standard truck for 99 has a larger injector, Thanks again guys.
Old Oct 3, 2005 | 10:09 AM
RATTLINRAM's Avatar
Do you know if his truck is a ETC -SO (Standard Output) or is it a ETH - HO (High Output).
Edit: I wasn't thinking It has to be a ETC due to it being an auto. ETH only available with 6 speed.
This statement from Dodgeram.org:
The HY-35 builds boost a little more quickly than the HX-35 does when the engine load is light, so from an emissions standpoint the HY-35 is better suited to stop-and-go driving with an automatic transmission.
FWIW: The HY-35 and HX-35 are functionally equivalent under most engine loads, and the wastegates on both turbos are set for the same boost level. The HY-35 does not breathe as well as the HX-35 at higher speeds under a heavy load. The choke point of the HX35 is around 35psi; the HY35 chokes at about 29psi.
Old Oct 3, 2005 | 10:14 AM
hotdram's Avatar
The ETH (HO) was only available from the factory with the 6 speed manual.
~Rob
Old Oct 3, 2005 | 10:17 AM
RATTLINRAM's Avatar
GEEZE Rob,,,,,,,,
Give me a chance to figure out when my brain is asleep!,,,, I thought about it right after I posted,,,,,,,,,,,,,,,,,, You're QUICK
Old Oct 3, 2005 | 10:25 AM
RATTLINRAM's Avatar
*NOTE to self*
Change setting in data base for hotdram - Posting Time Limits = > Once every 15 minutes
Old Oct 3, 2005 | 11:13 AM
1qckdodge's Avatar
So its all in the turbo then, wow I didnt think that would make that much of a drivabilty difference, so the turbo is the only difference? not injectors or injection pump pressures, thanks again guys.
Old Oct 3, 2005 | 11:55 AM
hotdram's Avatar
*NOTE to self*
Hey, after being on this site for a little over 2 years, there are 2 things I definitely know, and one of those is that the 2nd gen HO's only came with the 6 speed, the other thing I forgot (but I think it is that Ford owns Cummins).
~Rob
Old Oct 3, 2005 | 12:43 PM
RATTLINRAM's Avatar
Not saying that it's ALL in the turbos,,,,, but there is a some difference according to Dave Fritz's site. I've seen stock trucks that were the same year, set up the same way, perform much different from each other. I would guess that there could be a bunch of contributing factors why the two trucks seem different.
Old Oct 7, 2005 | 09:44 AM
BIGHEAD's Avatar
I have noticed a similiar difference between 99's & 01's. I have a 99 that did come set at 215 hp which I had a cummins tech go in & reprogram it to the 235. They were able to do that. I didn't notice any difference at all. My buddies 01 is bone stock & it is as powerful as mine was with an ez on my truck, or close to it. By the way Ford owns about 7% stock in Cummins, so I would not say that Ford owns Cummins. There is something different about these trucks,& it may very well be the turbo. I just don't know.
Old Oct 7, 2005 | 02:47 PM
displacedtexan's Avatar
~Rob
Yep, that's it. They just bought 'em. And while they were at it they fixed the 6.0.
Old Oct 9, 2005 | 04:42 PM
hotdram's Avatar
Originally Posted by BIGHEAD
... By the way Ford owns about 7% stock in Cummins, so I would not say that Ford owns Cummins....
Ford no longer owns any part of Cummins, its just a running joke around here.
Check out the FAQ page from Cummins.com Does Ford Own Cummins?
~Rob
MikeRP
79
Nov 21, 2016 10:19 PM
Blessed
Jul 21, 2013 12:00 PM
Bookshelf
May 18, 2011 04:20 PM
gman2310
Oct 25, 2006 03:02 PM
SPINPOSI
Aug 24, 2006 10:44 PM
