High suction pressure on AC
Old Jun 26, 2006 | 06:48 AM
matchhead's Avatar
Question High suction pressure on AC
I have the right amount of freon 2 lbs. in the system, the high side presure is all right but the low side goes from 45 60 lbs. of suction pressure, 95 dodge ram diesel
Old Jun 26, 2006 | 08:08 AM
Flashpoint's Avatar
that sounds about right , 40-60 is ok unless you mean you have a problem of some sort. How cold is your air getting thats what really matters.
Old Jun 26, 2006 | 08:56 PM
jrs_dodge_diesel's Avatar
Remember that the pressures depend on several factors,
design of the system
whether or not the system has the proper amount of refrigerant
temperatures
With your windows down, A/C on Max, with the blower on High, the air coming out of the vents should be 30°-40° below ambient air temperature. When I get home from work I will look in my A/C books and look up the proper pressures for you.
Old Jun 27, 2006 | 07:20 AM
Ok, I just dived into my books.
The proper amount of refrigerent needed is exactly 2 lbs of R134a, like you mentioned earlier.
Proper operating pressures are as follows :
Low side (suction) is 32-40 psi
High side (discharge) is 190-220 psi
Let me know what you get for pressure readings and if your A/C isn't doing what it's supposed to do.
65pacecar
Aug 3, 2009 09:14 AM
sammy340
Jun 8, 2009 11:06 AM
bradshaw106
Jul 13, 2008 04:01 PM
qwest
Aug 9, 2007 04:16 PM
