Fuel Module at Tank, Which one is Suction and Return
Old Jul 31, 2009 | 10:36 PM
65pacecar's Avatar
I have a 2001 3500, the fuel module on the top of the tank has the module with the electrical connector and beside it (towards the back of the truck, looking at it from the drivers side) is the two fuel lines, which one is suction, which one is the return? Also, any tips on releasing the "quick" connect lines with breaking the plastic module?
Thanks.
Old Aug 1, 2009 | 10:47 PM
Mountain Grown's Avatar
if it's like the 2500, then the hoses should be slightly different sizes.
The smaller one is the return line. Just squeeze the plastic tabs in and it should come out. If full of dirt and grease then clean out the workings of the connectors with some sort of spray carb cleaner or similar, if difficult to remove.
Old Aug 2, 2009 | 12:08 AM
Fishin2Deep4U's Avatar
You can use a zip tie to squeeze the clamps.
Dave
Old Aug 2, 2009 | 09:35 PM
65pacecar's Avatar
Thanks, I got it today, any tips on getting a hose on a Push Lok fitting, I can get it almost on but that last I am about 1/8" of an inch from getting it all the way up.
Old Aug 2, 2009 | 10:50 PM
Fern's Avatar
Use a little 2 stroke oil on the inside to lube it up.
Old Aug 3, 2009 | 12:48 AM
Oils are not necessary.
A small amount of heat from a heat gun is all it takes. They will slip on, take shape and not leak.
You only need to be over 2 barbs to get a complete seal. We will be providing the newer fittings to the manufacturers after he current supply begins drying up.
Dave
Old Aug 3, 2009 | 09:14 AM
65pacecar's Avatar
Thanks, I have everything over the second Barb, just cant get it to push the rest of the way up. I'll try the Heat Method.
sammy340
Jun 8, 2009 11:06 AM
Bradleysram
19
May 12, 2009 08:36 AM
bradshaw106
Jul 13, 2008 04:01 PM
qwest
Aug 9, 2007 04:16 PM
matchhead
Jun 27, 2006 07:20 AM
