Heat OK AC OK NO Defrost Fan?
2002 Dodge 2500 Diesel - All heater settings work fine and all blower speeds work great... Same with A/C all work fine. Issue is no defrost air in either selector setting on the selector ****. The fan stops when defrost is selected.
Any Ideas? I have read a lot about the HVAC but it doesn't seam to be a door issue.
Could it be a bad computer control module? I'm told that there is no connection between the door moving and the blower working.
Just not sure where to look now?
I haven't heard of this problem before so after looking in the book of lines it shows the "mode selector sw" directly provides a ground for the blower in all positions except off. You need a new mode select sw or could try cleaning the contacts with contact cleaner first.
it may require 2 or 3 applications before you get it in there and cleaned.
06RAM2500
Jan 1, 2010 10:57 PM
Halnrvs
Jan 25, 2006 09:43 PM
