Heat OK AC OK NO Defrost Fan?
2002 Dodge 2500 Diesel - All heater settings work fine and all blower speeds work great... Same with A/C all work fine. Issue is no defrost air in either selector setting on the selector knob. The fan stops when defrost is selected.
Any Ideas? I have read a lot about the HVAC but it doesn't seam to be a door issue. Could it be a bad computer control module? I'm told that there is no connection between the door moving and the blower working. Just not sure where to look now? [duhhh] |
I haven't heard of this problem before so after looking in the book of lines it shows the "mode selector sw" directly provides a ground for the blower in all positions except off. You need a new mode select sw or could try cleaning the contacts with contact cleaner first.
Thanks I will be getting into the mode select this next week and try cleaning first.
Originally Posted by nascar-co
(Post 3287296)
Checked the switch and it must have warn contacts. After switching it a few times (30) or so it started to work. Think I should replace it for a long term fix.
Thanks |
(Post 3288548)
Thanks |
