No defrost or heat
Old Feb 7, 2005 | 09:48 PM
Craig93's Avatar
No defrost or heat
This morning I could not get any forced air to the defroster or heat ducts, only the vent duct. Temp is normal out of the vent duct but as soon as I select heat or defrost I lose all forced air, no output at all, move it back to vent and I have normal fan and heat output. My feet are freezing and my windows do not clear for some time...going to be late again tomorrow .
I'm assuming it is one of the actuators or vacuum switch? Thing that confuses me is the lack of forced air in defrost or heat, the blower motor isn't controlled electrically by these vacuum actuators is it?
Also, when switching from vent to defrost and back to vent, there is forced air out of the defrost duct for about two seconds then the duct closes. I hate these vacuum pods, give me a cable anyday.
Anyone have any ideas where to start? I believe I have good vacuum still.
Craig.
Old Feb 7, 2005 | 10:11 PM
Hemi Cat's Avatar
It sounds like there is some movement when you select a different mode, so the problem is low vacuum. Either the source is low or leaking or the control is leaking or a vac diaphragm is leaking. My guess would be that since you live in a cold climate, the age of your truck, basic description of the problem, that the control is leaking internally. Probably if you play with the control **** you may get some function change out of it.
Good luck
Old Feb 7, 2005 | 10:20 PM
Craig93's Avatar
Thanks Hemi, I'll play with the ***** some more tomorrow, hopefully it will fix itself
Old Feb 7, 2005 | 10:45 PM
Dr. Evil's Avatar
Hey Craig, ya didnt buy that 98??
Old Feb 7, 2005 | 10:48 PM
Craig93's Avatar
No I didn't, just didn't get a good feeling about it, ya know what I mean? Not sure if it's still available. I'm still looking though!
Old Feb 7, 2005 | 11:43 PM
Dr. Evil's Avatar
I did the same thing...even went so far as putting 10% down....and then walked...I was lucky to get my $$ back from those shysters. I cant believe how much $ a 98 12V commands up here. Guys in the US are buying them for 12-13k?? And they are $20-25k up here. What gives?
Old Feb 8, 2005 | 04:28 AM
kd460's Avatar
Sorry, off topic, quick note:
Hey, Dr. Evil, I just read "Currently in HELL", are you from Hell Michigan? If so, we are neighbors, I live in Brighton, and am in Hell often (go to the farm in Unidilla).
Let me know, Kevin
Old Feb 8, 2005 | 08:28 AM
Dr. Evil's Avatar
Uh no....Kevin, Im currently in Western Canadian Hell.... 2 hours from nowhere....
Old Feb 8, 2005 | 11:21 AM
Lil Dog's Avatar
And I am about 2 hours NW of Hell Canada...
Nickelback's hometown BTW...
Old Feb 8, 2005 | 01:17 PM
Dr. Evil's Avatar
yup.... AND Lanny McDonald ...
Rock on boys...!!
Old Feb 8, 2005 | 05:54 PM
kd460's Avatar
OK, just to clarify, there is a town in Michigan with the actual name of Hell. When I read that statement, I thought you lived there. Is there actually a hell, in canada or is it hell in canada . Kevin
Old Feb 8, 2005 | 08:25 PM
Dr. Evil's Avatar
actually, the place I live in is HELL....although the town is named something else.
There is no other HELL in Canada (except for Winnipeg.... )
91Hoopty
Jan 9, 2014 03:44 PM
06RAM2500
Jan 1, 2010 10:57 PM
mabchewy
Mar 4, 2009 06:09 PM
corn binder
Nov 24, 2008 08:44 AM
Halnrvs
Jan 25, 2006 09:43 PM
