Headlight, Key, Door Chime
My dad just bought a 94 ram. The door/headlight/key chimes were yanked out before he bought it. Does anyone know the wiring diagram for the plugs to the left of the fuses to add an aftermarket buzzer to get the headlight warning to work again?
It a single module the plugs in under the knee bolster... I pull mine out so I can listen to the CD player when I'm working in the yard without the buzzer.
Go to a wrecking yard and pull one out... the plug it in...
Originally posted by TN Redneck
Thanks for the tip. I am going to look for that dang thing this evening so I can leave the door open and enjoy the stereo.
Does it have any identification or ist it obvious when you pop the knee bolster off?
I already have a generic buzzer I would like to use, just don't know what connectores to use. Anyone have any ideas?
I unplugged the wire from the key switch on mine. It still dings if the lights are on and the door is open, but does nothing if the key is in the ignition with the door open. The down side to this is, the ring around the ignition switch does not light up, no biggie. If you drop the plastic cover from the underside of the steering wheel column, by the key switch, there is a plug with 2 or 3 wires right there. Just unplug it.
dodgetrucker75
Dec 19, 2012 04:41 PM
hovisimo
17
Apr 21, 2005 09:22 PM
procrastinator
19
Feb 15, 2005 11:06 PM
jrs_dodge_diesel
23
Nov 25, 2004 12:00 PM
