Tech Tip : How to shut off annoying door chime.
Old Nov 20, 2004 | 07:33 PM
jrs_dodge_diesel's Avatar
Lightbulb Tech Tip : How to shut off annoying door chime.
Ever have to work on the interior of the truck and need the doors open, and want to listen to the radio? Except that when you put the key in the door chime keeps going and gets old real quick . I have found out how to silence it. At least on the second gens. Underneath the drivers side dash above the brake pedal, look for a green connector and simply unplug. Door chime will stop. However remember to plug it back in as the same module controls the interior lights. It may be different on different years, mine is a 01. Just listen to get a general location, and look for a small box, put your finger on it when its chiming, you should feel a slight vibration on every ding. If so, you found it.
Old Nov 20, 2004 | 07:47 PM
CJ's Avatar
CJ
Man I've wanted to know how to shut that thing off for a while now. Thanks
CJ
Old Nov 20, 2004 | 08:26 PM
ratsun's Avatar
If you just want to silence the alarm you can just push the pin switch in that is on the front of the door jam once and it will silence the alarm untill the key is cycled again
Old Nov 20, 2004 | 08:44 PM
firestorm's Avatar
Well it don't work for mine. I was going to look for the one wire that signals "key-in-ignition" and snip it. I have a hide a key, but have not needed it except for when I was running late and couldn't find my keys, so I am not worried about being locked out. I still want it to tell me if I left my lights ons when the door is open. I just have not had the time to look for it.
Old Nov 20, 2004 | 08:49 PM
That did not work for me, I have to hold it in.
Old Nov 20, 2004 | 10:12 PM
firestorm's Avatar
I came across this in the third gen. section, posted by Tom Bolitho.
"I am not sure about the 03 but on my 01 there are two wires attached to the back of the tumblers. I just unplugged them. All function of the damned dinger work except the key in the ignition."
Old Nov 20, 2004 | 11:06 PM
wagontrain131's Avatar
I just ripped out the whole buzzer module. It got rid of that annoying buzz sound when you turn your truck on too.
-Kyle
Old Nov 20, 2004 | 11:32 PM
Dufrain's Avatar
yep i took out that light blue box and no noise and lights work fine
Old Nov 21, 2004 | 04:36 AM
Yeah, it looks like it is different on different years. I unplugged mine while cleaning out the truck, The chime got real annoying real quick. When I unplugged the connector (I was already looking up as I was under the dash) I noticed the interior lights went out when I unplugged it. They came back on when I was done and plugged the box back in.
Old Nov 21, 2004 | 07:46 AM
lawnpro's Avatar
I just turn the key on and it stops
Old Nov 21, 2004 | 09:07 AM
Geico266's Avatar
If I turn my key to assessory and open the doors I get no beeping.
Am I missing something?
Old Nov 21, 2004 | 11:52 AM
GSP's Avatar
GSP
Just pushing the door pin switch worked on my truck
Old Nov 21, 2004 | 04:56 PM
gwhammy's Avatar
I run a screw threw da dinger!Tried unplugging it but the cruise quit, don't make any sense but it did and worked when plugged back in.
Old Nov 22, 2004 | 04:16 PM
CTD NUT's Avatar
Wow...it's amazing how different years work differently for even the silliest things like door buzzers, sheesh! Gotta keep those DC engineers employed, I guess.
Old Nov 22, 2004 | 08:17 PM
wgingg's Avatar
if i hold my door pin for a second then no more beep. cool trick thanks
