fuel sending unit
Old Dec 30, 2004 | 06:09 PM
ARAcummins's Avatar
fuel sending unit
Well I was about a mile from my drive way and my fuel gauge drops from just under half tank to emptey, fuel light comes on and it dings at me. I am guessing my sending unit just went bad, right?
Has anyone replaced this befor, if so, how bad of a job is it and how much is it going to cost me.
Thanks
Heath
Old Dec 30, 2004 | 06:53 PM
RATTLINRAM's Avatar
Here is just one of the threads from doing a using fuel tank sending unit
Old Dec 30, 2004 | 07:53 PM
Geico266's Avatar
I've done it twice. Long story, but its not a bad job really. The biggest pain is getting most of the fuel out of the tank so you can drop it. The tank is not heavy empty.
Also, if I were you I would replace all of the fuel line quick connectors by cutting them off and using 2 hose clamps each line to the fuel module. Make sure the little arrows line up aon the module and the tank when you put it back togeather.
HINT if you see a little green ball floating in your tank throw it out. That is what happened to me. It is the anti-spill valve ball incase of a roll over accident. Mine got into the tank and hung up the sending unit.
Old Dec 30, 2004 | 10:01 PM
ARAcummins's Avatar
Does anyone know for sure if part number 4797738 is the right sending unit for my 95? Is it only about $40?
Heath
Old Dec 30, 2004 | 10:17 PM
RATTLINRAM's Avatar
Heath
If Bill (infidel) says that's the number,,,,,,, I would bet my next years salary on it being correct! He has two 95's also,,,,
Old Dec 31, 2004 | 07:02 AM
infidel's Avatar
That can be a trick if the gauge doesn't work.
That's one reason why I always tilt the bed up instead, so much easier.
The number and price was right as of 6 months ago.
on edit the current price is $47 just plug the number -4797738- in here http://www.trademotion.com/partlocat...OEM&siteid=835
Old Dec 31, 2004 | 05:40 PM
ARAcummins's Avatar
Funny thing I got about a mile from the house this morning and up she came. Then every time I hit the brakes she would drop then after a bit it would come back up, almost like it is too sensitive. Thanks
Heath
Old Jan 2, 2005 | 12:23 PM
suttonbeeman's Avatar
Mine quit for second time and I started using a lubricant in fuel and it is working fine now.. dont know if lubericant had anything to do with it or not....anyone else had any experience like this?
Old Jan 2, 2005 | 02:20 PM
infidel's Avatar
Quite a few people have said useing Marvel Mystery Oil caused their gauges to mess up but after use was discontinued the gauge went back to normal.
Southern Pride
May 18, 2010 07:47 AM
JasonblkZ06
May 16, 2009 08:02 PM
powerwagon440
23
Mar 12, 2004 12:44 PM
dcwm
Jun 13, 2003 12:27 PM
figure_9_pro
Nov 11, 2002 08:53 PM
