Fuel pressure too high????
Finally installed a fuel pressure gauge. It reads 25psi at idle and will move up to 35psi @70. Is this too high, and if so, what can I do to bring it down, but not change the pressure at idle? Thanks in advance.
Originally Posted by MKELLY
If your fuel pressure is 25 psi @ idle it should drop @ 70 mph not increase. Mine idles @ 22 psi and will drop to 19 psi @ 75mph.
Unless I'm misunderstanding your question.
Still seems odd to me.
And no, 35psi is not to high on a 12v.
I for one am jealous of you 12v guys and your fuel pressure. I didn't know so many of you monitored your fuel pressure, do the mechanical pumps fail often. I have been thinking of going to a new cam so I can run a mechanical pump. I'm on my 3rd one and it was acting funny the other day while towing.
CJ
CJ
CJ
CJ
Monitoring your FP also prevents needless filter changes saving you time and money. Changing the filter based on mileage is redicuolous, one bad tank of fuel and the filter could be clogged in 10 miles. On the flip side I know a fellow who went 62k on the stock fuel filter that came with his new truck before it finally clogged.
With my FP gauge I don't usually see a drop in pressure that indicates it's time to change the filter until around 30k.
tinknocker827
13
Dec 4, 2013 06:26 PM
GlennRMK
May 24, 2007 10:46 PM
cheff
Jan 23, 2006 09:44 AM
RowJ
33
Sep 15, 2005 07:00 PM
ridofpwrstroke
Apr 22, 2005 04:58 PM
