Dually tire question......
Old Feb 23, 2003 | 11:28 PM
CMN_NOT_STROKN's Avatar
Re:Dually tire question......
I run Hercules Terra Trac A/T and get around just fine in snow in 2WD. Very rarely do I put it in 4wd. I do weigh a little more than most, but I don't have a problem getting anywhere. I also have 255/85/16. They are taller but only slightly wider than a 235/85/16. They fit just fine on the stock rim and they don't touch in the rear. Although it is close(1/2&quot. When I do put it in 4X4 I can just about floor the throttle and get nearly no slip. Actually, tonight its snowing out and was cruising around with my buddy. For fun I put it in 4X4 and at a stop light took off in 2nd gear and killed the engine! These tires are enough to bog the engine in 4" of snow!!!
Old Feb 24, 2003 | 03:24 PM
me4osu's Avatar
I use Michelin LTX MS tires, and yes, I have driven in snow &amp; ice away from home. Not a problem. For the E rating they were around $165 a pop. <br><br>I would try the XPS tires that Pit Bull mentioned. If you use the truck for its purpose stay with the &quot;E&quot; load range. All those other tires for $99 buck are probably &quot;C&quot; range or passenger rating.
Old Feb 24, 2003 | 09:33 PM
TX Ram's Avatar
The Kelly AT's that I mentioned run about $99 per tire and are definitely E Range. I would not put anything less on my truck.
Old Feb 24, 2003 | 11:58 PM
DuallyJeff's Avatar
I also run the Michelin LTX MS on my 2wd dually. To this date I have never been stuck in the snow with them (except once) and they always seem to find a good grip. The one time I slipped the *** end into the ditch in front of my house and nothing short of 4wd would have saved me there. But as far as running on the roads (paved and non paved) I get around.
Yes they are a expensive tire but I feel well worth it for a year round daily driving and working E range tire.
Old Mar 18, 2003 | 10:06 PM
jr22's Avatar
how about a mtr from goodyear ? or a procomp a/t tire has a 50k warranty, jr
gafirefighter
Sep 24, 2007 11:11 AM
dieselfuelonly
May 24, 2007 08:15 AM
HDBeauty
Sep 11, 2006 08:16 PM
epenn03
Jan 5, 2006 03:39 PM
j28s
Oct 14, 2002 09:48 AM
