Dead gauges
Dead gauges ("no BUS" display)
My dad fired up his '01 this afternoon and all gauges were dead. Check engine lt. was on, airbag and abs lights were on. where the odometer is he gets NO BUS. any ideas? Thanks RB
This has happened to me a couple times. I just pulled the gauge cluster out and cleaned the contacts on the back and in the dash. Sometimes took a couple tries, but it's always come back on.
Sounds like your CCD buss is not working. Have you done any work under the dash ? If not, there may be a problem with the Central Timing Module. This is the box behind the ash tray. Depending on the truck model it will have 1 or 2 25 pin cables out of it.
Sundays outcome
Pulled instrament cluster and cleaned and greased pins, checked all fuses and reinstalled...... No worky. I know we got power to the gauges because they move slighly when we turn the ignition switch on. Guess it goes to the shop this week. Thanks for all the input.
Thanks for all the help. I checked the ground in the power dist. box and found the previous owner must of had the same issue. There were scrape marks on the bottom of the ground lug. So I rescraped the lug and it works! Well most of it. The speedo is pegged at 120mph, Just performed the diagnostic check of the instrament cluster and it recalibrated everthing. Good to go, Thanks to all who weighed in on the problem, saved pops $$$$$$$
Kman9090
29
Dec 6, 2007 06:43 PM
coontz0473
17
Sep 22, 2006 03:52 PM
