CTD Weight vs Tire Max Load
I have been researching tires for the last couple of days here, and I have a question that needs to be clarified. During my tire information search, I pulled this quote from the forum:
"I weighed my truck today with a half tank of fuel. 7,160 lbs. 2890lbs rear 4,270lbs front."
My questions come from these specs I pulled off the manufacturer's site:
Cooper SST 285/75R16 "D" - Max Load 3305
BFG Goodrich AT 285/75R16 "E" - Max Load 3750
1. If these are the max loads of the tires, where does our front end weight of 4,270lbs have an effect?
2. Is the difference between a D and E tire that significant (445lbs) if I am not towing ever(maybe 200 miles per year)?
From: My head lays down in Murrieta, but the day light hours are spent in San Diego, Ca.
I wouldn't worry too much about the "D" and "E" rating myself. You just gotta be sure the weight if the drivers and/or the front axle doesn't exceed the tire max weight. So basicly what does your front axle weigh when fully loaded? Take that wieght and divide it by two. Does that exceed the max weight listed on the side of the tire? Do the same for the rear axle. It's all about wieght distribution.............. Hope this helps ya...........
The discussion about D and E range tires has come up before. Some people say it doesn't matter whether you run a D or E as long as your weight is within spec. I personally disagree. I think an E tire is much more robust than a D tire and at least for safety's sake, I wouldn't run anything but a E tire when towing. If you run around empty all the time then a D would be fine. But if you're in the market for new tires, why not just get all E's?
carwash
Sep 12, 2007 11:39 AM
4RnrRick
Feb 27, 2007 11:25 AM
logan21sv
Jul 28, 2006 12:49 AM
